It's £35 for the version with the 1156 mount. The only place you can realistically save money without compromising on quality is by dropping the monitor down to a smaller size, or getting a slightly less powerful GPU (like a 4850 or 9800GTX+) though you could also save £10 by getting this PSU.
So you put the more expensive RAM back in? That's £15 right there. And why did you go for a more expensive monitor? It's no better than the other LG one or this Acer.
The Acer monitor you suggested does not have a HDMI input. As for the Ram, i completely forgot about the link you sent me, but with post and packaging i might as well just get the XMS3 kit.
Ahh, again i have been naive, better take it off the list. But, how does the G.skill kit compare to the corsair kit ?
They're exactly the same speed and latency, so you won't notice any difference at all. Memory is memory
okay, thank you very very much for your help in finishing the spec off +1rep ! Ordering it this afternoon, one last question : will it fit in the case ?
Done, done and done Ordered the above setup, minus the ram which i bought here. Now I need to work on paying it all back Well worth it.
