Hardware Asus M4A79-T Deluxe
Discussion in 'Article Discussion' started by Tim S, 21 Apr 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. Jenny_Y8S
    Jenny_Y8S Guest
    You say you don't care about SAS ports, but want more SATA. I know SAS ports probably cost more than SATA only but you can use them this way. (I do)
    Still glad I got my i7!
  3. Guest-16
    Guest-16 Guest
    An extra SATA chipset costs less than a SAS/SATA ;)
  4. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    They completely ruined the layout and removed all neat parts compared to the old.
    So when do we get to see the new Gigabyte AM3 boards????
  5. Kúsař
    Kúsař regular bit-tech reader
    23 Apr 2008
    Asus' deluxe boards used to be bigger overkill. Though 5 SATA is enough, it's not overkill :) .
    I don't think absence of clear CMOS button is problem. When MB fails to post BIOS fallback to default settings.
    The only bad feature is FDC. There's no need for this zombie-tech anymore, especially since BIOS can emulate USB floppy as FDD.
    Also page 4 is slightly puzzling my mind:
    "'MSI 790FX-G70 (AMD 790GX/SB750 - .131 beta BIOS)"'
    It should be 790FX instead of 790GX, shouldn't it? Or maybe it's new board, I've seen only GD70(790FX) on MSI site.
  6. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    5 SATA isn't enough. Besides that, features be damned, there really ARE corners cut here. Hell, some of the non-deluxe Intel boards have a better feature set. It almost makes me wonder if Asus has chosen to shun the core feature set in favor of overclocking, leaving Gigabyte (and their ghastly support) to pick up the tab.
  7. Guest-16
    Guest-16 Guest
    Fixed. Copy and paste error :blush:
  8. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    The board's colours are so yuk! How is the X3 720 & friends, overclocking guide coming along?
  9. Guest-16
    Guest-16 Guest
    Give us a chance.. jeez :p
  10. Turbotab
    4 Feb 2009
    Oh I forgot this is not the Inquirer, you actually have to test things:naughty:
  11. flaunt
    flaunt What's a Dremel?
    13 Dec 2007
    So you blew it up overclocking a chip and yet recommend it for overclocking... Makes sense.
  12. [USRF]Obiwan
    9 Apr 2003
    Lol
Tags: Add Tags
