ASUS P5B-E and USB HUB
Discussion in 'Tech Support' started by dutchcowes, 20 Nov 2006.
  1. dutchcowes
    dutchcowes less is more
    2 Feb 2002
    Hi just got this board, all works fine including overclocking etc. (it’s even stable!,however it's not latest revision 1.02g :sigh: )
    Have connected a belkin powered usb hub where my webcam and headphones connect into.
    Comes up as generic usb hub in device manager and all is well.
    When I switch computer off for a while and the start up, usb hub does not get recognised in windows and webcam and headphones don't work.(no green lights on the hub)
    Take the usb lead out of the usb port and plug it back in then after a couple of times it will find it again,when I do a restart this problem does not occur.
    Setting in Bios in USB configuration: legacy USB support enabled
    Plug and play O/S enabled
    Latest bios
    E6400
    2 gig ram
    xp
    Any ideas?
    Thanks.
  2. Krikkit
    21 Jan 2003
    Try enabling legacy support? Changed the USB port it's in?
  3. dutchcowes
    2 Feb 2002
    hi,
    legacy support is enabled, will change ports and give that a go.
    Thanks
  4. dutchcowes
    2 Feb 2002
    Nope still same problem will e-mail asus and see
