Hardware Asus Sabertooth P67 Review
Discussion in 'Article Discussion' started by arcticstoat, 28 Apr 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. VipersGratitude
    VipersGratitude Multimodder
    4 Mar 2008
    Can you put percentage bars underneath the score fractions?
    With the old scoring system I could digest the verdict with glance, now I can't...
    While I understand the logic of the scoring system, it could be represented better visually.
    8am. Fractions...It is definitely a step backwards.
  3. confusis
    confusis Kiwi-modder
    5 Jan 2006
    Whats under that panel just under the cpu? I must have missed it in the article :S
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    CMOS battery perhaps?
    Nice board, but I wonder if removing the shroud would have let it hit that mystical 5GHz...
  5. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    Bah, should have mentioned that. It's a removable panel with a tiny 40mm (i think) fan mount and 3pin power header behind it. It allows you to add a fan to blow more air behind the shroud. The fan isn't included in the box.
  6. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    That hole is for a 40mm fan, it even has a connector to you connect the fan if u need extra cooling.
    I have mine like this
    And although the "armor" is closed all around (the only way to get air inside is really thru the cpu fan facing down), the chipset always remains at 28ºc.
    I had both boards, with this B2 error, I spent a little more and got the little update from the P8P67 to this Sabertooth, it's a good board, I only bought it because I wanted to use my wi-fi card and my Creative X-Fi Titanium (and my P8P67 didn't have enough pci-ex 1x, one got blocked by the gpu)
  7. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    91%, 73%, 60%. Opening the calculator doesn't take long ;)
  8. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    That black shroud looks ugly as sin.
  9. V3ctor
    10 Dec 2008
    It looks good on real life :D
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    For some reason the Sabertooth boards always pwn in gaming!
  11. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    If the shroud can be removed, can it be painted?
  12. Guest-16
    Guest-16 Guest
    Sure why not. :rock:
  13. V3ctor
    10 Dec 2008
    I already saw some painted somewhere in the web... they look great, now u can personalize your board :) modders/tuners rejoice! :)
  14. Siwini
    Siwini What is 4+no.5?
    14 Sep 2010
    New scoring system is confusing. Were the performance tab anyway? I dkn if I like this new upgrade
  15. Guest-56605
    Guest-56605 Guest
    Its my weapon of choice in my new build and its one sexy bit of kit!!!!! :rock: :thumb: :D
    Photo's really do not do it justice I assure you :nono:
    The purists will probably hate it as always however :duh:
  16. TARIKK
    TARIKK Minimodder
    19 Feb 2009
    It is for a 50x50x10 mm fan.
    Did you manage to fit all those cards without any problems ? If you have a photo please can you share, because I had some issues to install the extra cards.
    thx.
  17. neil_b
    neil_b Minimodder
    20 Jun 2009
    +1 for percentage bars; if it aint broke, don't fix it... change for change's sake is not a good approach.
  18. Claave
    Claave You Rebel scum
    29 Nov 2008
  19. neil_b
    neil_b Minimodder
    20 Jun 2009
  20. V3ctor
    10 Dec 2008
    I'll do it, but only at 6pm (when I arrive from work).
Tags: Add Tags
