Case Mod - In Progress ATCS 840 by PoLoMoD -> The end ... 05/12
Discussion in 'Project Logs' started by PoLo, 15 Aug 2011.
  1. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Sponsors : Big thanks for their support !!
    for money :D
    For a "Platimax 850w", 4 Apollish T.B. UCTA12N-R and 4 Apollish T.B. UCTA14N-R
    For a reduction of about 70% of a big order >> here<<
    Sorry for the translation because I'm french .
    Here I am with a project on a CoolerMaster ATCS 840, still no precise ideas in the design of the case but it will contain a final configuration full watercooled .
    This first page will be updated regularly with links to not having to read all pages (if worklog achieved several pages of course) .
    The project must meet several conditions :
    - Integrate in-house 3 radiators (a PHOBYA G-Changer 420 and 2 MAGICOOL Slim 240) .
    - The configuration must be full Watercooled (CPU, GPU, MOSFET, RAM) .
    - The case should remain as simple as possible .
    La Config :
    - EVGA P55-Cheesecake
    - INTEL i5 750
    - CORSAIR Dominator 2x2Go PC12800
    - MSI R5870 1Go
    - XFX 5870 1Go (bios MSI)
    - THERMALTAKE Toughpower 700W
    - SSD CRUCIAL M4 64Go
    - WESTERN DIGITAL Caviar black 640Go
    - WESTERN DIGITAL Caviar green 640Go (x2)
    Le Watercooling :
    - PHOBYA G-Changer 420
    - Laing DDC-1T
    - Réservoir Alpacool
    - EK-FC5870 CF Nickel-Acetal + Backplate Nickel
    - Masterkleer 11/16 Dark Red
    - Embouts EK, feser, phobya
    - Enermax Apollish 12 & 14
    - MagiCool SLIM DUAL 240
    - Laing DDC-1T
    - EK Suprem HF full Nickel
    - EK RAM Dominator
    - ANFI-TEC EVGA P55 Cheesecake full cover
    - ANFI-TEC 028 EVGA P55 + ANFI-TEC 029 EVGA P55
  2. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Reserved ...
  3. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Receipt of the PC case : (Cooler Master ATCS840 black)
    Removing the case :
    Some pictures of the actual hardware :
    EK DCP 4.0 and combo DCP 4.0 140mm :
    4x2Go G.Skill RipJaws and Arctic Cooling RC :
    MSI R5870 and EK FC-5870 Nikel :
    EVGA P55-Cheesecake, ANFI-TEC P55-Cheesecake Nikel and ALPHACOOL nexXxos X2 HF Nikel :
    Group photos :
  4. jrs77
    jrs77 Modder
    17 Feb 2006
    Ah nice. The ATCS 840 is still one of the best ATX-cases around.
    Will you do any mods to the case itself or leave it stock and only do the hardware?
  5. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Yes, the ATCS840 is a very good case.
    I will not only integrate the hardware, I'll create some changes.
  6. Mosquito
    Mosquito Just 'Plane' Crazy
    24 Mar 2011
    I'm anxious to see you get the triple 140 and the pair of dual 120 rads in there... looking good :thumb:
  7. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    I painted the cart on the motherboard :
    Installed water blocks EK Supreme, Anfi-Tec EVGA 028 & 029 :
    Modification of the water block ANFI-TEC P55 EVGA 200 lightcover (it is incompatible with the motherboard EVGA P55 conventional) :
    I painted the water blocks Anfi-Tec EVGA 028, 029 & 200 lightcover :
    fixing creation of the PHOBYA G-Changer 420 :
  8. Stark.Jr
    Stark.Jr What's a Dremel?
    22 Mar 2011
    Nice big start :) i will follow!
    //S.Jr
  9. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Looking good
  10. Warsmith
    Warsmith Enginseer
    5 Dec 2010
    Subbed!
  11. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Fixing the PHOBYA G-Changer 420 at the top :
    Sleeving the 24 pins :
    Remove the HDD cage and the cage change bay 5,25" :
    Creation of fixing radiators (2 x 240) :
    Cutting a window on the door
    Marcos_Viegas likes this.
  12. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    I like this, I like this a lot!
  13. MilOk
    MilOk What's a Dremel?
    18 Dec 2010
    nice work =)
  14. mav2000
    mav2000 In Training
    16 Oct 2010
    Wow nice work...am working on an ATCS myself..
  15. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    I love the cut of the window, is 800D style, realy awesome!
    Congratulations! :thumb: +rep
  16. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Thanks
    I saw your ATCS840 ... Good project!
    Yes, I copied the window on the 800D.
    I ordered some parts today:
    - Pump Laing DDC-1T
    - Plexi Bay Reservoir XSPC Dual Laing DDC pumps for 2
    - Fittings compression 15.9 / 11.1
    - Fittings EK @ 90 °
    - The Feser Company wall passes
    - Tubing Masterkleer 15.9 / 11.1 Dark Red
    - Sleeve color MDPC-X-X
    - Screw M3x6mm Black MDPC-X
    - M3 Brainwasher MDPC-X
  17. Marcos_Viegas
    6 May 2010
    i used that style im my case too... :hehe:
  18. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Today I started the cladding in red, the change of screws, changing the red pipe, replacement of barbed ends by caps and reorganization of the tubing:
    The HD5870 before :
    The HD5870 after :
    The 24pins wrapped :
    Changing the motherboard screw :
    I return to work ... :D
  19. PoLo
    PoLo PoLoMoD
    15 Jan 2011
    Cladding on the motherboard almost finished :D
  20. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    amazing :jawdrop::rock:
