Case Mod - In Progress ATCS - Tweaked
Discussion in 'Project Logs' started by PcJunkie209, 5 Apr 2014.
  1. PcJunkie209
    PcJunkie209 What's a Dremel?
    3 Sep 2011
    Hello everybody! Its been awhile since I have used forums to post progress of a build. Fcaebook is like a bad drug that I am trying to get away from. I need to hire a lacky to do my social media stuff LOL. Anyways I am in the process of redoing an OLD CM ATCS case. Some ask why? I say why not? It's so cool, at least to me, to see an old chassis made look new with modern tech incorporated into it. So I was all excited when a friend offered me this chassis. :)
    So the idea for me is to create a lan friendly chassis instead of some ginormous case. I will be rearranging the whole inside and inverting the mobo. I have already started a lot of my fab work. I will try to keep my log here some what current. ;) So on with some specs and pics.
    Specs -
    Asus Rampage 4 Gene
    Nvidia GTX690 x 2
    Intel i7 4960X
    Intel 730 series 480gb ssd x 3 in raid 0
    Adata XPG 1866mhz 32gb ram
    Cooler Master ATCS chassis
    Cooler Master JetFlow 120mm red LED fans x 6
    Cooler Master V1000 PSU
    Koolance blocks, 360 rads, pump and misc fittings
    Primochill Revolver fittings
    Primochill CTR res
    Primochill Vortex flow meter
    Primochill 360mm rad grills
    ModSmart pre-sleeved wire cut to length
    The chassis was in fairly good shape when i got it. A little dirty and covered with logos. So here is how the case looked when I got it.
    So here is a new product I tried to help with my fab process. Keep in mine I have never tried much braising. Here's some pics of the new frame for the front
    Here is a pic of the sub-frame for my mobo tray .
    And some pics of how the case will look....
    More to come soon.... Until then.
  2. PcJunkie209
    3 Sep 2011
    Alrighty ladies! Here's some more progress. It has been crazy here.
    So lets start with some of the fabrications i've done. And of course the awesome feet. :)
    Here's a look at the corners after i cleaned up some of my braising.
    Then of course the part I usually screw up. The I/O panel cutout.... lol
    This time I measured like 10 times. :) Looks good. So I then marked out psu cutout...
    Next up marked out the window and the front plate. Today I will be cutting all these fun things.... :)
    Last but not least I laid out some of the hardware to see if all is well. Then I marked some wire management holes. Its gonna be tight fit with dual 360 rads but hey what the hell i'll make it work. :)
    Thanks for checking out my log. More to come very soon. Until then......
  3. PcJunkie209
    3 Sep 2011
    So I am trying to bring this log up to speed. So bare with me.....
    Ok so I think I am overdue on some pics. In case you missed the first video here's a link.
    Lets start off with the front grill cutting
    Next I would like to thank Primochill and ModSmart for sending me some goodies for this build.
    Lets check out the goodies!!
    They also send me the CTR res but the pic didn't come out too well :(
    So lets get down to business. The next pics will pretty much wrap it up. I was very pressed for time to knock this build out to take to lanfest. I did finish in time so sorry for lack of more pics. :(
    Here's few pics of some of the hardware getting blocks installed. R4G and 690's
    Here is the build getting some assembly after getting parts back from powder coating. The color is a 2 stage powder chrome base with transparent red over it.
    Moving on to res, pump and flow meter layout and install.
    Start button installed and it works!!!! Yay (had a switch go out recently.)
    top rad grill looks great
    For the tubing I did use PETG tubing, thank you Stuart! So here are my first bends...
    And leak test
    Door on and died liquid red. No window yet. lol
    So thats it for now. I will take some pics in the sun in a couple days. Until then..........
  4. Nexxo
    23 Oct 2001
    The ATCS case is a real classic. Good choice.
  5. PcJunkie209
    3 Sep 2011
    Thank you. Here's some better finished pics.....
    Hope you guys like. :thumb:
  6. lowfat
    lowfat Minimodder
    4 Jul 2013
    Nicely done. :rock:
  7. TheViscountGodrich
    TheViscountGodrich Wannabe modder.
    12 Apr 2014
    A really nice clean red look.
    Like it!
  8. PcJunkie209
    3 Sep 2011
    Thanks guys!
  9. Nexxo
    23 Oct 2001
    Can I suggest you change the radiator grille screws for some nice HT steel socket capscrews though?
