Graphics ATi Drivers
Discussion in 'Hardware' started by Hamish, 1 Oct 2003.
  1. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    right, got my 9800, installed it, reinstalled windows
    tried those omega drivers, they installed alright but then said it was going to do some tests or sumat on restart, i restarted the monitor went to standby mode and after a while it rebooted
    did that lots of times, finally went into safe mode and uninstalled them
    wtf was that all about?
    official Cat 3.7's didnt help
    tried uninstalling SmartGart too, didnt help
    tried the 3.6's on the CD same thing
    HELP, 1280x1024 @ 60hz is killing me
  2. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I haven't ever had any problems with the Omega drivers. Of course I don't have anything as fancy as a 9800. :D Did you uninstall the drivers you had loaded prior to trying to install the omegas?
  3. Hamish
    25 Nov 2002
    it was a clean install of XP there were no other drivers
    and i have uninstalled and reinstalled the omegas, cat 3.7, cat 3.6 several times trying to make this f**$@&£&"£& thing work :wallbash:
    and to top it all of my speakers refuse to work properly in 5.1 mode, even tho its set up IDENTICALLY to how it was before
    i even have a bloody screenshot of the old install
    :wallbash: :wallbash: :wallbash: :wallbash: :wallbash: :wallbash:
  4. Deviate
    3 Jun 2002
    From the omega readme:
    Not sure if that has anything to do with your refresh rate. I don't have XP, so I don't know too much about how to help with that. I did see on the omega site that he has a newer driver (9/20/2003) that supposedly fixes some 9800SE something.
  5. Hamish
    25 Nov 2002
    i cant change anything monitor related because it doesnt know what gfx card it is
    i was using the latest omega drivers....
  6. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    YOU FIXED IT!!!!!!!!!
    My god I love you... :D
    Since I reinstalled Windows, I couldn't get 1152x864 to work at 75Hz, which I know my monitor supports, even though it was fine before...disabling this worked...I know I should read readmes and stuff, but it's so much more fun when someone tells you the answer :p
    Thanks :clap:
  7. Deviate
    3 Jun 2002
    And it's so much more fun for me to be able to tell you the answer (and boost my ego a bit in the process :D ). Hamish, have you been able to make any more headway on your problem?
    Edit: oh yeah....I love you too. :worried: :lol:
  8. Hamish
    25 Nov 2002
    i did eventually get it to boot but there were artifacts in windows, Dx7/8 was really poor performance and loads of corruption
    Dx9 resulted in this
    taken it out and put my 4200 back in :(
    RMA time me thinks
  9. Javen
    Javen What's a Dremel?
    1 Sep 2003
    Hamish,
    What MoBo/Chipset are you running... I have just finally gotten to the bottom of some of my Radeon problems, which has involved all sorts of Voltage tweaks, different drivers, different DX versions etc.
    If you want, you can email me: lee at sensateinteractive.com
    And I'll put you onto some of the pages I've been through to resolve this issue.
    Javen
  10. Hamish
    25 Nov 2002
    sent it back now, general consensus was that it was DOA
  11. Javen
    1 Sep 2003
    Fair enough, mate :)
    Just thought I might be able to help... I had considered RMAing mine a few times, but now I've got it working its the dogs back wheels!
    Javen
