Scratch Build – In Progress ATX Cube Case (26 Aug 07 - Completed! But not entirely...)
Discussion in 'Project Logs' started by Dean MF, 22 Jul 2007.
  1. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Hey, thank you very much. The plexi comes on and off using allen cap screws. This way I can remove any panel without any hasles :)
  2. Guest-23315
    Guest-23315 Guest
    That looks really nice and 'Mountain-Moddy'
    Nice work on the acrylic.
  3. Jonny_tinslecat
    Jonny_tinslecat General Potcher
    10 Aug 2007
    just been looking through the whole thread, i cant see how you mounted your psu, it it directly to the Plexi, looks like there is 4 bolts on the back, or is it attached to the frame?
  4. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    The psu sits snugly in the frame and I have only 2 screws that attach it to the pleci for a bit of support. It doesnt sound like much, but it wont go anywehere :thumb:
  5. Jonny_tinslecat
    10 Aug 2007
    good stuff, have to think about that for my case
  6. josyd
    josyd mmm cheese...
    22 Oct 2007
    i didnt see it mentioned... (though i could be wrong)... but whats the thickness of the acrylic?
  7. Teyber
    Teyber ******
    18 Mar 2007
    yeah dude anything happenin with the case lately?
  8. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Hey, I almost thinks its 3mm ;) It could be 5mm though.... LOL - sorry, will check it tonight when I get home and let you know.
    Hey Teyber. No my friend, its been very quiet with the case lately. I still need to sort out the cabling mess on the inside. But, I have to say, so far, everything has been running extremely smooth with the case, no problems at all :thumb:
  9. josyd
    josyd mmm cheese...
    22 Oct 2007
    thanks.. i ask because i discovered bit-tech maybe a month ago.. and seeing all the mods in the modding section made me wanna make a case.. but not just mod an existing on.. then a few days ago i realized there were mods in the forums too :wallbash:... crazy thing is.. this is almost the exact same thing i was planning.. and i didnt even see this til thursday.. strange...
    edit: d**n nice case btw
  10. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Thanx a lot man!
    The best advice I can give you is to spend a lot of time planning every single thing you want to do. Make sketches, ensure that everything will fit and that your case will meet your specific needs.
    Hey, once you start, create yourself a project log on this forum, post the link here, and you will get a hell of a lot of encouragement and help all the way. Good luck!!!
  11. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    WoW! That looks cubalicious!
  12. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    LOL. Thanx man!
  13. Guest-23315
    Guest-23315 Guest
    It does indeed look nice and cubey!
  14. josyd
    josyd mmm cheese...
    22 Oct 2007
    did u ever check the thickness of the plexi?
    also.. what did you use to cut it? ive heard mixed things about what to use
  15. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Yeah, its 3mm.
    I used a jigsaw to cut the plexi. But leave about a 1mm on the sides, cause you gonna have to do a lot of sanding. Start with a very very rough paper and work your way to a very smooth one. I used 80 (dry), 220 (wet), 800 (wet), 1500 (wet), 2000 (wet).
    Cut slowly to avoid cracking the edges!
  16. B[x]
    B[x] What's a Dremel?
    3 Jul 2006
    Sorry if you've mentioned this in previous posts but how many TPI do the blades you use to cut the acrylic have?
  17. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Hey. Not sure... but I used a generic cutting blade with the teeth facing downwards.
  18. radodrill
    radodrill Resident EI
    14 Mar 2006
    I use metal cutting blades for acrylic (maybe 14 TPI). Mark everything out first; then cut as close to the lines as possible; then just sand smooth.
  19. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Exactly what he said :thumb: Trust Radodrill, he's the plexi expert :hip:
    Cut slowly to avoid cracks though ;)
  20. radodrill
    14 Mar 2006
    hehe I'm flattered :blush:
    yeah slow and steady cutting speed is best.
    and to get a nice shine on the edges I hit them with novus #2 and a cloth buffing wheel after the wet sanding.
