Audio artifacts on 360 while playing orginal xbox games
Discussion in 'Gaming' started by xrain, 5 Sep 2006.
  1. xrain
    xrain Minimodder
    26 Jan 2004
    Some times when I play original xbox games on my xbox 360, I get a loud screech, that sounds like a mix between static and gears grinding. It only lasts for about a 1/4 a second but it scares the crap out of you cause its unexpected. I have a Logitech Z-5500 5.1 surround connected to the xbox via optical cable.
    Its only happenes when I play original xbox games, not during movies, or 360 games. Any past experiances with this happeneing to you? Any idea on what it could be? I'm thinking it. Thanks for the help
  2. atanum141
    22 Jul 2004
    Have you updated the 360?
    Maybe its a software issue with its backwards compatibility?
  3. Veles
    Veles DUR HUR
    18 Nov 2005
    Are you playing KotOR by any chance?
  4. xrain
    xrain Minimodder
    26 Jan 2004
    Yes Kotor and fable... and yes I have updated the xbox. they were the ones I noticed it in... I guess it didnt do it when I played Chaos Theory... I'll have to test the other games for it too...
  5. Tibby
    Tibby Back Once Again
    9 Oct 2005
    I had a similar problem when I first got my xbox and I played Perfect Dark.
    I would hear loud machine noises for ages, and it would come and go.
    Very annoying seeing you have to restart to get rid of it.
