Peripherals Audio Interference - When loading BF3
Discussion in 'Tech Support' started by mat0tam, 21 Dec 2011.
  1. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    hi all,
    Playing lots of BF3 atm on my Pc using headsets + on desk mic. Getting interference through my headset when ever the game starts, its just a constant drone/buzzing and it turns out its going through my mic to other people too which is a pain.
    Any ideas on how I can resolve this? Or whats causing it. Moved both away from power cables but still no success
    Confuuuuused x
  2. Deders
    Deders Modder
    14 Nov 2010
    What soundcard are you using?
  3. mat0tam
    1 Sep 2011
    Im not using one, its my on board audio
  4. Deders
    Deders Modder
    14 Nov 2010
    That might be the problem, probably motherboard interference. I expect a cheap but decent soundcard would eliminate this.
  5. mat0tam
    1 Sep 2011
    Also just ordered a few snap on ferrite cores just incase :)
  6. Mojo
    Mojo Multimodder
    18 Nov 2011
    ill endevour to send the best i can find in the scrap bin :D
  7. mat0tam
    1 Sep 2011
    Your a hero :)
  8. mat0tam
    1 Sep 2011
    Ferrite core arrived, put them all over and have limited interference. Not removed it totally though :s .. need to remove them 1 by one and work out which was the culprit now
