Case Mod - In Progress Autob0t Sk1ds "worklog"
Discussion in 'Project Logs' started by AciD_RaiN, 23 Aug 2012.
  1. AciD_RaiN
    AciD_RaiN What's a Dremel?
    29 Jul 2012
    This will be my 3rd mod but my first worklog here. My other mods can be found in my signature. Hope you like it :)
    Hardware:
    CPU: Intel i7 2700k @4.5GHz
    MB: Asus Sabertooth P67
    RAM: Corsair Vengeance 4x4GB 1866MHz
    SSD: OCZ Vertex 3 MAX IOPS
    Storage: External
    GPU: GTX 680
    Case: CM Storm Trooper
    PSU: Corsair AX850
    Watercooling:
    CPU block: EK-Supremacy - Nickel - Plexi
    GPU block: EK-FC680 GTX - Acetal+EN Nickel
    Rad 1: Phobya G-Changer 360 Ver. 1.2 Black
    Fans: 3x Scythe 120MM Gentle Typhoon 1850RPM D1225C12B5AP-15 - pull
    Rad 2: Mayhems MHE240 LE Quad pass heat exchanger.
    Fans: 4x NOISEBLOCKER 120MM NB-BlackSilentPRO PL-1 - push/pull
    Pump: Laing D5 with matt black mod kit
    Reservoir: Bitspower 150 upgrade kit / black mod pump top
    Fittings: Bitspower matt black
    Tubing: Masterkleer
    Liquid: Mayhems Pastel Mint Green
    Other:
    Case fans: Scythe 120MM Slip Stream 800RPM on HDD bay & Nanoxia DX Series 140MM DX14 - 700RPM in the back
    Monitor: 42" Philips FULL HD TV
    Mouse: Logitech G700
    Keyboard: Logitech K350
    Official sponsors:
    Special thanks to:
    [​IMG] <--- My local hardware store for always doing some free work for me
    Lets start with some pictures of the case
  2. AciD_RaiN
    29 Jul 2012
    These are the fans I will be using in pull on the 360 rad in the top (more on that later how I will be fitting a 360 rad in the top)
    I was really unhappy with those colored wires so I decided to sleeve them and change the connectors as well
    The Mayhems radiator is just very plain and awesome and plain awesome :)
    I thought it was necessary to have a window so I ordered the windowed side :)
    Now starting some paintwork
  3. AciD_RaiN
    29 Jul 2012
    A little update :D
    Did some painting on the mesh on the window side, painted the mayhems radiator and some fan grills :)
    And here is the case pretty much naked
    My little nephew totally agrees that the handle has to go :p
    Took a bit of drilling and dremeling to get it off but in the end it came off :D
    Next up: Making room for the 360 rad in the roof :D
  4. AciD_RaiN
    29 Jul 2012
    This will be my last update for now. I just need more money to buy more stuff so I can continue.
    These are the front panel cables That I won't be needing
    So these are the ones that are left :)
    Making everything ready before I start cutting for the 360 radiator
    Now I can fit a 360 rad in the top but there is still one problem...
    Here is the handle after I cut it to the right size. It will only serve as a visual effect but won't be able to hold the case
    And the handle fits just perfectly
    Now the problem I had with fitting a 360 rad with pull configuration was that the top panel wouldn't have fitted on top of the last fan so I had to cut into the plastic. I was kinda scared that I would screw it up and ruin the case but it turned out really well in my opinion :)
    Now I have to leave the case like this until I can get me some more supplies and things I need for this like case feet, u-channel and some other stuff that will be shown when the time comes. Hope you will enjoy and follow the rest of my worklog :)
    Please if you have any ideas post them and if there is something I could have done better please let me know :p
  5. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    I like what i see :)!
    You are doing the same mod as TTL :D
  6. AciD_RaiN
    29 Jul 2012
    Is it exactly the same? So I'm just a copycat then :wallbash:
  7. AciD_RaiN
    29 Jul 2012
    I got lent some money so I could go get my custom made car paint and continue at least a little. Here's a little preview of what I did today :)
    Started by adding the painted fan grill and a fan to the HDD bay
    Painted some of the mesh on the case
    And I painted the 360 rad.
    More on the results of today's work tomorrow. Stay tuned ;)
  8. AciD_RaiN
    29 Jul 2012
    The 360 radiator painted, with the dust filters on
    I had to get the handle better fitted so my cat's won't jump on top of it and it falls off so I added a layer of hot glue first so the handle would sit in the right position.
    Handle fitted with hot glue
    And the handle sits just perfectly :)
  9. KoSoVaR^
    19 Dec 2010
    Exactly the same on the top :)
    Check TinyTomLogan's fbpage or youtube videos :)
  10. AciD_RaiN
    29 Jul 2012
    Yeah I checked it after I read your comment. I was actually taking this idea from skitzab1 and changing it a little. Well as it says in south park, "Simpsons did it" I probably have some original ideas in the future on this build to make up my copycat ways ;)
  11. AciD_RaiN
    29 Jul 2012
    Well I finished all the painting so I decided to share it from all sides :)
    And the top again when it's on :p
    Found some U-Channel in my drawer so I decided to try it out. I tried mounting the radiator with a fan and everything fits even though it's a little thick :)
    I had to finish my can of car paint so I painted the extra side just for fun. Actually looks better then I thought but doesn't look really good though lol
    Now I need to wait for all the parts and components so there won't be any update for some time now. I hope you like it so far and hope you will follow my worklog :)
  12. Shurika
    Shurika Minimodder
    9 Mar 2012
    Don`t you think to replace the cap on the lowest the same as the rest? so do not get out of style
  13. AciD_RaiN
    29 Jul 2012
    Sorry English is not my first language. Are you talking about the aluminum plate in the bottom with the storm logo on it ??
  14. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Thank you for wearing socks! :thumb:
  15. AciD_RaiN
    29 Jul 2012
    Really -_-
    Edit: Sorry I had just woken up when I saw it but now I think it's funny. Not sure if someone wants to see my tattooed feet :)
  16. Shurika
    Shurika Minimodder
    9 Mar 2012
    My too. I mean this
    to replace with the same as higher
  17. AciD_RaiN
    29 Jul 2012
    ohh yeah there will be a fan controller in the top so this will disappear :) I was just trying it out like this since it will be replaced anyway so thanks for your well appreciated tip ;)
  18. skitzab1
    skitzab1 What's a Dremel?
    21 Apr 2012
    lookin sweet there mate keep it up love the green and hay its called modding not patenting--
    stick to your plan and fire them guns :)
  19. AciD_RaiN
    29 Jul 2012
    Thanks mate. Your support means a lot to me and you have been a great inspiration to me on this one :) It's not a complicated mod or a massive modding but it's my 3rd mod and I've only been modding for a few months. I think it will turn out just the way I wanted it. I just need a few components and parts to finish :)
  20. barry99705
    20 Apr 2008
    :D
    Too often we have build logs with some dudes gnarly feet.
