Windows Automatic diskpart?
Discussion in 'Software' started by MonkeyBoss, 12 Mar 2012.
  1. MonkeyBoss
    MonkeyBoss What's a Dremel?
    24 Jan 2012
    I wipe a lot of hard drives in work and was wondering how i could go about getting diskpart to run automatically. can it be done with a batch file?
    the commands i run are
    SELECT DISK 2
    CLEAN
    CREATE PARTITION PRIMARY
    FORMAT FS=NTFS QUICK
    ACTIVE
    ASSIGN
    any help would be great
    thanks
  2. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    batch file it?
  3. MonkeyBoss
    24 Jan 2012
    how would i create a batch file for it? never used them before
  4. Margo Baggins
    Margo Baggins I'm good at Soldering Super Moderator
    28 May 2010
    for diskpart you can't put the diskpart inside a batch script as it opens its own shell, you need to do..
    diskpart /s diskpart.txt
    you have to make a text files called diskpart.txt and put it inside one of your "paths". inside diskpart.txt put..
    SELECT DISK 2
    CLEAN
    ACTIVE
    ASSIGN
    EXIT
    Thought I have never tried it, you could probably then make a batch file of the diskpart /s diskpart.txt
    Somethin like,
    @echo off
    echo About to run diskpart...
    echo Diskpart complete!
    pause
    To save the above bit as a batch file, put it in a text file and change file type to all files and save as whatever.bat then it will be a batch file :)
    Then it should hopefully run diskpart with your text file input, then pause for input before it closes the script window.
    (to see what/where your paths are, open cmd and write "set" then look for PATHS, it should be a list of folders where you can have stuff and just reference it from command line and it will use it without having to have the full path input, you can add and change these paths.)
    EDIT: found it, here is the microsoft KB about scripting diskpart http://technet.microsoft.com/en-us/library/cc766465(WS.10).aspx if you look towards the bottom it says exactly what you want to do.
  5. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    I guess you could use powershell, but thats a different thing all together
  6. Margo Baggins
    28 May 2010
    its so much harder using powershell! I dont think its a very good idea. Its only viable using powershell becuase it sits ontop of .net. I don't think it represents a very elegant solution.
    MonkeyBoss likes this.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    You do know that's not a secure way of wiping a disk.
    All the data will still be recoverable because a 'quick' format doesn't physically overwrite any data it just sets the partition table to say it's all blank.
  8. MonkeyBoss
    24 Jan 2012
    we got a pretty got solution for wiping drives, this is a seperate thing, thanks for the info guys, will have a go at it later
    +rep
