Back in the fold but need help...
Discussion in 'bit-tech Folding Team' started by clanseven, 11 Sep 2017.
  1. clanseven
    clanseven What's a Dremel?
    11 Jun 2014
    Hi.
    Now summer has passed, I'm back folding. However, despite downloading the client and using my name and the correct team number, etc, my points don't seem to be accumulating to me on the Custom PC 7 bit-tech stats after about 12 hours continuous folding. Any ideas what I'm doing wrong?
    Thanks in anticipation.
  2. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Usually a triple check of the exact name and the exact team number sorts most people out - because typos can, and do, often creep in.
    Do you also have a Folding Passkey - has this been entered correctly?
  3. DocJonz
    24 Apr 2009
    Perhaps I should have looked at the stats first ... might be that the third party stats sites are having issues again. Did you check your ExtremeOverclocking stats page or the Stanford official stats page - the former might not be updating at the moment, but the latter should.
  4. clanseven
    11 Jun 2014
    Thanks for the quick reply.
    Yes and yes! I have just noticed that the stats server has been down, so it could just be that. I hope...
  5. DocJonz
    24 Apr 2009
    Seems like the Stanford stats server is down - according to the official site - and, as term hasn't started, there are limited staff, so things aren't so speedy in getting back up and running.
  6. DocJonz
    24 Apr 2009
    @clanseven - Are you collecting points successfully now the stats server has been migrated?
  7. clanseven
    11 Jun 2014
    Hi Doc,
    Yes, thank you. all is well now.
