Other BACKUP SOLUTIONS - HARDWARE/SOFTWARE
Discussion in 'Hardware' started by diseases, 20 Feb 2009.
  1. diseases
    diseases What's a Dremel?
    20 Feb 2009
    im looking for help on trying to pick out a backup solution for my system
    ((x1 500 gig data drive))
    ((x1 75 gig OS drive ))
    VISTA 64-BIT
    i think one 640/750gig external hard drive would be the most suitable, all-in-one option
    QUESTIONS:
    > i use this system as a image/video/audio work tool so the bulk of data is under constant change/revision
    >>What is the most appropriate method of back up (full volume back up?/taking an image of the drive?)
    AND
    what additional software would i need to have to perform the operation?
    >ive looked at seagate/western digital/buffalo external drives and have read different stories talking about incompatability with vista 64bit as well as slow data transfer speeds
    >>Can someone help me pick out an external hard drive (ideally with USB2+Firewire connections) that is 100% compatable with my set up
    OR
    >>>Or an enclosure to house the drive in myself? (im finding it difficult to locate an appropriate enclosure availible to me in the UK)
    if anyone could help me with any of this or at least point me in the right direction i would be really grateful,
    all the best
  2. davidfield375
    davidfield375 Hardware Mods
    3 Feb 2009
    1TB drives are fairly cheap now, I would recommend a western digital, I believe they have interior fans which helps the drives from over heating. I know somebody who purchased an external drive without a fan and on large data transfers it would struggle with over heating.
