I am using the wireless Microsoft XBox 360 controller with my computer to play madden 2008. I am also using the Logitech Z-Cinema speakers. When I plug the controller in, all the audio goes hazy and scratchy. Even if I unplug the controller, the audio stays the same until I restart my computer. I am wondering if there is any way to fix this, or if I should just give up the madden on the computer and get an XBox. If I do do that, would I be able to have the speakers and my monitor plugged into both my computer and the Xbox?
Try this thread mate http://www.fixya.com/support/t231270-xbox_360_controller_windows_causes_fuzzy near the middle theres some people chatting about using a seperate USB port (like a chassis USB port or a USB port that isnt on you rear IO panel. either that or go into your sound properties and enable "use only default devices" hope that helps
