Electronics battery powered Weller soldering iron any good?
Discussion in 'Modding' started by star882, 3 Mar 2006.
  1. star882
    star882 What's a Dremel?
    19 Mar 2003
  2. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    Depends, for an all around use soldering iron I think it's a bad idea, for that your best bet is a standard Weller 30W iron with a good tip.
    For a portable one to use in awkward places seems like a neat little tool, I don't think this one cools to the touch rapidly like the Coldheat but it seems to be quick at heating up in the first place.
    Hope that helps.
  3. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    If you want a portable soldering iron, I would recommend any of the solderpro series of gas soldering irons. They heat up within 3 seconds, and are really easy to use.
