Hardware Be Quiet! Dark Rock Pro Review
Discussion in 'Article Discussion' started by arcticstoat, 2 Apr 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. MaverickWill
    MaverickWill Dirty CPC Mackem
    26 Apr 2009
    Well, I certainly think THIS cooler deserves a crack at the Frio on LGA1366, don't you?
  3. Jim_Fear
    Jim_Fear What's a Dremel?
    2 Apr 2011
    1366 test seconded!
  4. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
  5. Cei
    Cei pew pew pew
    22 Mar 2008
    I'd love to get one, but I only just got a Frio...is this one any bigger than the Frio in terms of height though?
  6. Waynio
    Waynio Relaxing
    20 Aug 2009
    Seen this the other day & Tom says there are much better coolers & the mounting system needs revising, I agree & was a great review so was surprised to see such a good score here at first sight I thought this could be good but oh well maybe not.
    How come the prolimatech megahalems aren't ever included in the comparisons in reviews? it's a really good air cooler & can use your own choice of fans.
  7. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Corsair H-60, similar price, that's cooling solution I would go for.
  8. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    Still yet to find anything to realy be worth investing own my TRUE-Black with a couple of decent fans attached.
  9. Kasius
    Kasius Bringin' the dremolition
    16 May 2003
    Going to stick with my Frio till i buy some wc stuffs :)
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    Will it fit on Asus SB mobos with their heatsinks?
  11. Phifty Cal
    Phifty Cal What's a Dremel?
    28 Mar 2010
    I reckon this could do better than the Frio at a higher overclock. I mean the thing has 7 heatpipes!
  12. Material
    Material Soco Amaretto Lime
    13 Apr 2010
    As far as I'm aware yes. The only thing that fouled with our Fenrir was the AMD mounting lugs, so anything that doesn't use a unified (i.e. AMD and Intel) mounting bracket should be ok.
  13. Salty Wagyu
    Salty Wagyu moo
    5 Jul 2010
    Good review, think I may go for this to replace my Corsair H50. Hate the fact the H50 radiator needs a fan at full speed for it to work efficiently, which makes it extremely noisy (it's even a Noctua NF-P12). If I run it at 900rpm it will hit 90-100c otherwise.
  14. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    I've been using one since release.
    Great bit of kit, and so very, very quiet.
    Plus it looks sexy as hell :D
    Only downside - Normal sized Ram only ( no large heatsinks - Dominator etc. ) as it covers all 4 ram slots ( Heatsink covers 2 / fan covers other 2 )
  15. t5kcannon
    t5kcannon Minimodder
    7 Jan 2011
    Nice review, looks a quality item. Costly however.
  16. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    Awesome looking cooler, but I'm quite happy with my cheap and cheerful Tranquillo.
    As an aside, what's with the Intellitxt malarkey? I thought you guys categorically said you wouldn't be having them:
    This is the second time I've seen them today, both on the word 'performance' (the other was in the MSI 6850 Cyclone review, again on the last page, though after a refresh it disappeared).
    @edit: Ok, seems to be gone now, even though it was still there after 3 or 4 refreshes before I posted. What gives?
  17. t5kcannon
    7 Jan 2011
    Looks good. Which case out of interest, Im guessing Lian Li? Am I right?
  18. mi1ez
    mi1ez Modder
    11 Jun 2009
    Not sure that will fit in my flat, let alone my case! Looking good though!
  19. sWW
    sWW Minimodder
    3 Apr 2010
    When you get to this price level do the all in one water cooling kits not start becoming better value for money? i.e. the Corsair H50 and Antec Kühler H2O 620. Plus they don't take up your entire case! Is it possible to include these in the comparisons?
  20. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Anywhere that I can get this with shipping to Singapore?
Tags: Add Tags
