Guide Beginners Photography Crash Course?
Discussion in 'Photography, Art & Design' started by Dean R, 11 Apr 2013.
  1. Dean R
    Dean R What's a Dremel?
    18 Feb 2010
    Heya guys.
    Me and a friend are looking to go to New Zealand for 3 months in July. I want to be able to capture some great photos whilst I'm there because I may never get chance to go back. And basically I know very little about photography, so I decided to come here for some info.
    If anyone could recommend some good links or books to useful beginners photography guides that could help me at least get a decent shot. I got lost in all the google pages that are usually way ahead of my level at the moment.
    I'm basically looking to absorb as much info as possible before I go and get some practice in in the countryside near me.
    As another note, if anyone could recommend a decent beginners camera, I could probably afford up to £400 maybe. Although I may be borrowing my dads camera anyway so thats not really important.
    Thanks.
  2. Cheap Mod Wannabe
    Cheap Mod Wannabe What's a Dremel?
    7 Feb 2005
    What you will be shooting with is rather important. If it's a certain camera, then there might be no point in explaining certain technical points etc.
  3. supermonkey
    supermonkey Deal with it
    14 Apr 2004
    Go to your local library and see if they have something like Digital Photography for Dummies. Look for any other book that has relevant information. While you are reading the book(s), take your camera everywhere you go and shoot anything that might interest you. Play with the camera and learn what the settings do.
    Unless photography is something you're going to take up as a hobby, don't worry about getting a bunch of camera gear. Keep it simple, and err on the side of convenience over features.
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Take a look round the Digital Photography School website - they've got loads of useful info, including a bunch of beginner's guides.
    To be honest, though, getting the composition of your photos right is the easiest "quick fix" to taking good photos - as monkey said, you'll want to go for convenience rather than fiddle around with settings, and as long as you get the composition right, the auto settings should be fine for most situations.
