BELGIUM mod (RESPECT), polyworks@ the inside...time kill works
Discussion in 'Project Logs' started by djfrexx, 27 Dec 2004.
  1. djfrexx
    djfrexx What's a Dremel?
    27 Dec 2004
    :D hey all,
    So my second mod is started yesterday,
    This was my first mod, my second is a koolance that is in use.
    I have many ideas to re-create my case ..
    pîcs of today :naughty:
    The case naked///
    THIS IS MY IDEA:
    RE-created a clean front, DVD-RW will be usb connected.
    I will created a silence mod, all uneeded holes will be closed,and after all, there will be a clean Casemod, Watercooled :thumb:
  2. djfrexx
    27 Dec 2004
    This is my koolance:
    at back of picture u see my poly mod
  3. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    so...uh what are you doing?
  4. djfrexx
    27 Dec 2004
    question, is it posible to insert an amp. and speakers into a case? will crashe the HDD's? :idea:
  5. deadly-app
    9 Mar 2004
    how big? any large scale speaker will yes crash the hdds and erase them.
    if its small and a few watts....should be fine.
  6. Rekarp
    Rekarp What's a Dremel?
    7 Mar 2004
    or you can just surround it with some 16gauge steel and it should be fine. (someone correct me if im wrong on this)
    Looks like you want the case to have a flat front? Personally i think flat fronts are much more cleaner that others. :D
    Mod on !!
  7. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Probably the worst thing would be vibrations
  8. djfrexx
    27 Dec 2004
    maybe, if it is posible, i put a carampflier at the outside and in the side-panels 200 watts of speakers.. Should be nice, i think u can isolate them :idea: :hehe:
    some photoshops, witch one? :naughty:
  9. djfrexx
    27 Dec 2004
    ok, today i finished the front, it's beautyfull!
    One big reflectation, tomorrow ill post the pics, it's to dark to get pictures now :miffed:
  10. djfrexx
    27 Dec 2004
    today i started again with polyworks, tomorrow i will flatten all the poly..
    Pics can say more then words :rock:
    this is the front with the side panel on... this is to see that the front is legal :dremel:
  11. Silenced`
    Silenced` What's a Dremel?
    28 Aug 2004
    gl with your mod
    offtopic: i am from belgium to ( Oost-Vlaanderen )
  12. douphus
    douphus What's a Dremel?
    26 Aug 2004
    Not sure whats goin on there....is that bondo? What case is that on the very top?
  13. djfrexx
    27 Dec 2004
    ik ook van aalst :D :rock:
    The first mod is my koolance :thumb: The polyworks are prolonged,works. :wallbash: but :thumb: after all
  14. Rekarp
    7 Mar 2004
    very um..... interesting to say the least :D
    the tubes are going to be some kind of intake i bet.
    and um where are the Drives going :worried:
  15. djfrexx
    27 Dec 2004
    Lol Well the drive is extern (usb), because i have 2 pc's... :idea: :hehe:
    the tubes blow out the hot air, and the black ice at the undersite take cold air in :naughty:
  16. Jipa
    5 Feb 2004
    I like that idea very much! I'd anyway put power and reset buttons to frontpanel...
  17. speedybe
    speedybe What's a Dremel?
    18 Apr 2004
    Hier ook van België, koksijde aan de kust.
    Good luck with the mod
    GTZ
  18. djfrexx
    27 Dec 2004
    another day, poly works allmost finished, the top is ready now :clap:
    [​IMG] :rock:
  19. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Is this blue color actually paint?
  20. djfrexx
    27 Dec 2004
    yepz!
    Now de case is :duh: :hehe: soon :thumb: :naughty:
