Windows Best alternative to iTunes
Discussion in 'Software' started by cmberry20, 2 Jun 2011.
  1. cmberry20
    cmberry20 Mad Scientist
    16 Jul 2007
    Friend of mine is getting a bit sick of iTunes on his PC. Says it runs slow & a bit clunky!!
    Is there a really good (and free) alternative to iTunes out there? (must support iPhone4)
    There are loads out there, but its knowing which one works the best & is the most user friendly. Its like DVD ripping - just google that & you get 100s of 'free' programs that claim to do the job but very rarely do it well.
    Cheers.
  2. will_123
    will_123 Small childs brain in a big body
    2 Feb 2011
    Im sure the iPhone has to use iTunes...
  3. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
  4. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Media monkey gold will support iphone 4
    Sent from my GT-I9000 using Tapatalk
  5. cmberry20
    16 Jul 2007
    cheeky!!! :hehe:
    I know theres loads out there. But knowing whats good is the trick.
    Also, finding out if other people on this forum use one of these programs is a bonus because i can then get direct feedback on the quality of said software.
  6. Nealieboyee
    14 Aug 2009
    Blah blah WINAMP Cheesecake! :D Seriously though, winamp is awesome, and loads of skins etc.
    Hey everytime i write For the win it comes out as cheesecake. Try it! Eff Teee W
  7. adam_bagpuss
    24 Apr 2009
    you only just figured that out nealie
    hahah Cheesecake F T W
  8. OCJunkie
    OCJunkie OC your Dremel too
    19 Apr 2011
    I hate iTunes with every inch of my body and ditched my iPhone completely in favor of Android because of it. I still have an iPod though and use SharePod to load it, and there are others available. Media player is up to you but Winamp to me is the original.
