Graphics Best gpu for 150 or less?
Discussion in 'Hardware' started by Seglespaan, 8 Aug 2018.
  1. Seglespaan
    Seglespaan What's a Dremel?
    26 Aug 2011
    Hey guys.
    Long time some I last bought any pc parts. Don't even think crypto was a thing.
    So I just build my son a pc using some components. Some decent bits, i7, 256gb ssd, 16gb ram.
    But the only gfx card I could get is a 512mb Radeon number.
    Thought it would maybe do for playing fortnite but only playable on lowest settings.
    So question is. Should I buy a 1030 knowing it'll need replaced fairly soon. Or should I up the budget to a 1050 ti.
    Would either be able to play Detroit become human at decent spec / frame rate?
    Anything else I should be looking at around the same money?
    Cheers in advance.
  2. RedFlames
    23 Apr 2009
    not quite 'or less' but...
    1050ti... comes in at ~£160-170. the non-ti 1050 and the RX 560 aren't cheap enough [relative to the ti] to bother with imo but might be worth considering if the £150 is a hard limit.
    ...or see what you can get second hand.
  3. Goatee
    Goatee Multimodder
    19 Apr 2015
    1050ti can be had for £100 on Ebay, That would be my pick.
  4. Seglespaan
    26 Aug 2011
    I take it that's used for 100 on eBay?
  5. Goatee
    Goatee Multimodder
    19 Apr 2015
    Yep, I picked one up for that a couple of weeks ago.
  6. Seglespaan
    26 Aug 2011
