Software Best photo editing app for android
Discussion in 'Photography, Art & Design' started by satisfiedwimp, 13 May 2021.
  1. satisfiedwimp
    satisfiedwimp Minimodder
    21 Nov 2017
    Hey all! Can you please recommend some good photo editing apps for Android? TIA!
  2. Arboreal
    21 Jan 2011
    Snapseed?
    satisfiedwimp likes this.
  3. Big Elf
    23 Apr 2009
    Seconded
  4. satisfiedwimp
    21 Nov 2017
    I searched it on Google and it says "Snapseed is a highly efficient photo-editing application that is free to use and install. It is a part of Google's photo technology arsenal" Google uses it also so maybe I should go for it also. Thanks for the recommendation!
  5. satisfiedwimp
    21 Nov 2017
    My take: Snapseed does have limited brush abilities. You can dodge/burn, adjust exposure, and I think white balance is the third option. I like this app because it's easy and is the only one I've found to handle my LG phone RAW files correctly (all others with RAW capabilities on this phone glitch and result in a 1MP low-resolution jpeg export). That said, this seems to be a bug unique to this phone. I've also had some color retention issues on this app.
  6. Kiaz
    Kiaz What's a Dremel?
    1 Jul 2021
    PicsArt is also good photo editing app for android
  7. liamredskis
    liamredskis What's a Dremel?
    11 Nov 2022
    I use TouchRetouch. The app itself is easy to use and offers all the tools I need for removing unwanted elements from my photos. And it doesn't overcomplicate things. Basically, removing unwanted objects takes only a simple tap of your finger.
