Storage Best Sub £100 SSD
Discussion in 'Hardware' started by Poulter, 19 Apr 2013.
  1. Poulter
    Poulter What's a Dremel?
    22 Aug 2012
    Hey just wondering what the best sub £100 SSD is, will be just putting windows 7 and a couple of MMO's on it. Thanks
  2. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    There isn't really as the 120/128GB 6Gb/s SSDs are much slower than the 240-256GB ones, so i wouldn't want to recommend one.
    So i guess the best option that's nearest to your price range is probably the 250GB Samsung 840 @ ~£115 after cashback from eBuyer & the like... (you can also use TopCashBack with eBuyer & some other places for a bit more money back)
    it's something of a compromise drive though, d.t. using TLC nand, however it's faster than the (more expensive) 256GB M4, 240GB M500 or 240GB async nand SFs which are probably the other main mid-range performance choices...
    ...however without really increasing the budget then you've got to lose out somewhere.
