Cooling Best thermal paste.
Discussion in 'Hardware' started by Slizza, 21 Dec 2011.
  1. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    What's the best stuff these days?
  2. Tangster
    23 May 2009
    I-C Diamond is good stuff, as is Noctua NT-H1.
    I've also heard that Shin-etsu makes excellent thermal paste, but I've never used it.
  3. Slizza
    23 Apr 2009
    Thanks, was looking at the Antec Diamond stuff.
    Anybody else got a opinion?
  4. Big Elf
    23 Apr 2009
    This is worth checking out.
  5. shaunster1011
    shaunster1011 What's a Dremel?
    26 Sep 2011
    Ive found them all much the same really, ive used MX-4 in my current build and rate it, very easy to apply and great temps.
  6. feathers
    feathers Minimodder
    11 Apr 2009
    Too many coloured lines.
    Headache.
  7. Matarsak
    Matarsak What's a Dremel?
    26 Jan 2010
    Apparently Indigo Extreme is the best of the best, according to all the colored lines. Though I hear it's a bit of a headache to apply.
  8. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
  9. docodine
    docodine killed a guy once
    10 Feb 2007
    Doesn't make a big difference, just get what you've been happy with in the past.
  10. improprietary
    improprietary FT03 is a bitch to watercool
    13 May 2011
  11. karagiosis
    karagiosis Greed
    17 Jan 2011
    I've used MX-4 on my rig and i'm very happy with it. However, it's a pain to spread. I think MX-2 is the best option...
  12. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    I've always been a fan of arctic silver 5
    Sent from my HTC Sensation Z710e using Tapatalk
  13. lava
    lava Minimodder
    18 Sep 2010
    mx-2 for me
  14. Dwarfer
    Dwarfer What's a Dremel?
    30 Mar 2011
    I've always used AS5 - never had any issues with it and has always given me low temperatures!
  15. feathers
    feathers Minimodder
    11 Apr 2009
    Agree with some of you peckerwoods. I've read a lot of reviews saying how great this or that paste is and when I actually come to use it my temps aren't as good as with AS5.
    What gives?
  16. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    To be honest with the well known brands, in my own experience i've never noticed more than 1 or 2 degrees difference.
    Any well known brand, megahalems, arctic, gelid etc. would yield good heat exchange.
    Though.. I would stay away from the diamond based thermal paste, they're god awful.
  17. feathers
    feathers Minimodder
    11 Apr 2009
    Agree. I have diamond 24 I used once and totally removed the laser etching on i7.
    Temps worse than AS5. Actually I have the diamond on my 2 x 560Ti now so I assume the laser etched code has been wiped.
  18. Darkwisdom
    27 Aug 2011
    That's why i never even used the diamond stuff, i'd read around on these forums that the laser etching gets wiped. Plus temps are crud.
    I'm actually really happy with gelids brand of thermal paste. It keeps the temps down .
  19. Itchy Rim
    Itchy Rim Minimodder
    3 Jan 2012
    I use Arctic Silver 5.
    NB: The AS kits with the nice smelling fluids are a bit expensive for what they are, the AS cleaner 2 that is used is just analytical grade isopropanol or something very similar in analytical grade quality so that when it evaporates there is no residue.
    Any analytical grade organic solvent will do the job as long as it is in the 99.5% pure range.
