Cooling best way to clean a watercooling system?
Discussion in 'Hardware' started by MbayAQ, 25 Nov 2003.
  1. MbayAQ
    MbayAQ What's a Dremel?
    10 Feb 2003
    I was thinking of just flushing the system with some rubbing alchohol for a while....is that the way to do it?
  2. 13mur 6
    13mur 6 What's a Dremel?
    7 Nov 2003
    be very careful with alcohol as plexi-glass glues and such can get damaged via the use of alchol (so if you have a plexi-glass res. then don't use alcohol).
    -Lemur 6
  3. Guest-16
    Guest-16 Guest
    coke! :rock:
  4. Da_Rude_Baboon
    Da_Rude_Baboon What the?
    28 Mar 2002
    Would the sugar not leave it all sticky?
  5. Risky
    Risky Modder
    10 Sep 2001
    yeah, I'd be wary of that one. How much does this system need to be cleaned?
  6. Guest-16
    Guest-16 Guest
    Eh, worked here.
  7. Tim S
    Tim S OG
    8 Nov 2001
    use pepsi max :rock:
  8. Guest-16
    Guest-16 Guest
    LOL :rock:
  9. Tim S
    Tim S OG
    8 Nov 2001
    :thumb: :D :D
  10. MbayAQ
    10 Feb 2003
    so the only thing people use is coke? no one else ever cleans their system with anything else? my system seems like there might be some buildup in it from uv water dye and stuff and i wanted to flush that stuff out. also, i dont have a plexi res, but i do have a pump with epoxy on its input spout so im hoping the alchohol wont affect that either...
  11. Tyler Durden
    Tyler Durden What's a Dremel?
    3 Sep 2003
    Check aquatics shops for additives that do that job well.
    B-Clear is good I think.
    Removed the links as they seem dead...:(
    Hope that helps
  12. redhawk
    redhawk What's a Dremel?
    4 Nov 2003
    Here is the answer you really need. I found this on the web for you.
    Flushing and Cleaning out your Cooling System
    Hope this answer your question. :)
  13. Risky
    Risky Modder
    10 Sep 2001
    Good link there. Should be stuck up in our links sticky when its next updated.
