Case Mod - Complete Better than Compact Splash or not
Discussion in 'Project Logs' started by arduum, 6 Oct 2019.
  1. arduum
    arduum Minimodder
    10 Mar 2015
    Hi everyone.
    1st casemod on bt.:dremel:
    My English is very bad, but I will try to express myself :rollingeyes:
    Hardware:
    cpu - 9600k
    mb - z170i-pro
    mem - 2x8gb 2666
    gpu - gtx 1080
    psu - cheiftec sfx 650w
    ssd 1 - plextor m5s 256gb
    ssd 2 - adata s11 pro 512gb
    watercooling
    chrome tube
    Experimental case :naughty:
    Compared to the ss tj07 - looks like a baby. :hehe:
    A thick layer of metal. :rock:
    Plex window.
    Incredible brightness and color saturation, but I would like a darker tone... :worried:
    Dot_Kappa and wolfticket like this.
  2. arduum
    arduum Minimodder
    10 Mar 2015
    pcb on my pump doesn't feel good...
    diyink pcb
    my soldering skills leave much to be desired :rollingeyes:
    :blah:
    Cheapskate likes this.
  3. Cheapskate
    13 May 2007
    Neat! I know I have at least two dead ddcs. I'm a little worried about the sophistication of that board, though.
  4. arduum
    arduum Minimodder
    10 Mar 2015
    Cheapskate
    ddcs very hot, but this "custom" pcb has good review. we'll see soon
  5. arduum
    arduum Minimodder
    10 Mar 2015
    Jeff Hine
    I am of the opinion that it is not necessary to set the pump speed to the maximum, it is enough that it simply could not be heard.
    delieding 9600k
    The melting point of this solder is very small.
    More modifications.....
    Set for the poor 9600k + z170i pro:naughty::rock:
    Arboreal and Cheapskate like this.
  6. kim
    kim hardware addict
    10 Jan 2016
    :brrr: you know what you are doing it seems....:jawdrop: am I dreaming or you soldered together 2 pins of your CPU?, if yes, I never saw that before, amazing, sorry if I'm a dummy but would you be kind enough to explain the aimed result :idea:
  7. arduum
    arduum Minimodder
    10 Mar 2015
    Yes, but not necessarily soldering, I did it for my own personal reasons:rollingeyes:
    this manipulation is done for the operation of this processor on the motherboard z170/z270, etc.
    detailed information is very much on the Internet. link to YouTube as an example attached ;)
    https://www.youtube.com/results?search_query=coffee+lake+z170+mod
  8. kim
    kim hardware addict
    10 Jan 2016
    Thanks for the link, I get it now, I was puzzled and I searched about it on google but in my own language, it didn't matched the thing...great job :thumb: and BTW, cutee pink case
    Arboreal likes this.
  9. arduum
    arduum Minimodder
    10 Mar 2015
    Not at all:)
  10. arduum
    arduum Minimodder
    10 Mar 2015
  11. arduum
    arduum Minimodder
    10 Mar 2015
    Lifehack primochill revolver 1/2" + chrome tube 10/12mm
    _SAM1781.jpg _SAM1782.jpg _SAM1783.jpg _SAM1784.jpg _SAM1785.jpg _SAM1786.jpg _SAM1788.jpg
  12. Cheapskate
    13 May 2007
    I thought this was 'works as intended' ? I used 5/8" tube with 16mm fittings.
  13. arduum
    arduum Minimodder
    10 Mar 2015
    Cheapskate
    If you insert the tube as it is, it will dangle, not to mention it will leak.:happy:
  14. arduum
    arduum Minimodder
    10 Mar 2015
    after cleaning:lol:
  15. arduum
    arduum Minimodder
    10 Mar 2015
    drain:naughty:
  16. arduum
    arduum Minimodder
    10 Mar 2015
    a little bit chrome tubes:rollingeyes:
    Cheapskate and kim like this.
  17. arduum
    arduum Minimodder
    10 Mar 2015
    _SAM1858.JPG _SAM1861.JPG _SAM1862.JPG _SAM1863.JPG _SAM1872.JPG _SAM1873.JPG _SAM1996.JPG _SAM1998.JPG
    Aytos and Cheapskate like this.
  18. Cheapskate
    13 May 2007
    :thumb: You know it's a tight fit when it takes an entire year to get the tubes fitted.
    arduum likes this.
  19. arduum
    arduum Minimodder
    10 Mar 2015
    I lost the camera that had the photos on it during the move, but I found it today. :duh::hehe:
  20. Karrek
    Karrek Minimodder
    7 Jun 2011
    The cactus is bowing down to its new computer overlord.
    arduum likes this.
