Windows BF2 question about parachutes
Discussion in 'Gaming' started by sgtjudo, 14 Nov 2006.
  1. sgtjudo
    sgtjudo What's a Dremel?
    14 Nov 2006
    Is it possible to control where you land? I jump out and have seen guys glide back to land I always end up in the middle of the ocean and have to try to swim 5 miles to shore. UGH. :wallbash:
    Hope someone can tell me what im doing wrong. :naughty:
  2. Rav
    Rav What's a Dremel?
    26 Jul 2003
    Pretty certain wasd and mouse will control things ... iirc w will make you glide in a shallower angle, so you can go farther.
  3. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Just open the chute at the last minute.
  4. sgtjudo
    14 Nov 2006
    and what good will that do?
    if i open my chute at the LAST MIN and i am a mile from land meaning i am out in the water. i will stand land in the water. Ugh guys if your gonna answer atelast read my question.
    thanks for trying atleast. :idea:
  5. Veles
    Veles DUR HUR
    18 Nov 2005
    use normal movement keys when the parachute is open and you will controll where you go
  6. JesterQ
    JesterQ What's a Dremel?
    15 Jul 2004
    :thumb: agree ...
    another way to get a good feeling for this would be to get up really high, about 250/300 feet or until you just loose site of the ground. don't go much higher as the game throws an eppy and you end up getting pushed out of the gaming area and die.
    Bail out and hit the chute. Then play with the movement keys until to get a good feel for how they control your decent. not sure whether you can on a chute but the alternative camera angles might work which will help you even more.
    :hip:
  7. Guest-18698
    Guest-18698 Guest
    yep just use the normal movement keys, try and glide nice and early to get to a certain pos
  8. Hack'n'Slash
    Hack'n'Slash Minimodder
    20 Dec 2001
    I miss the HALO jumps on '42 & especially DC, the farting while free-falling all the way down still makes me giggle when I think about it. :D
    But yeah, in 42/DC, the 'chute was controlled by the mouse, in BF2 it's the direction keys which govern your descent.
  9. SeBbY_007
    SeBbY_007 What's a Dremel?
    30 Aug 2005
    Jump out of the helicopter (assuming you aren't going to irritate your team by using a jet for this) over place you want to land, then use your chute as you are about to hit the ground. Opening too early leaves you battling with the unresponsive movement you are limited to when gliding down, it also means you are highly visible and an easy target.
    Practice makes perfect.
    :thumb:
