Windows BF3 crashes
Discussion in 'Gaming' started by goldstar0011, 2 Jan 2012.
  1. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Am happily enjoying some BF3 gaming but it's randomly crashing (argghhh) mostly after a death or level reload.
    Any suggestions on checks to perform?
    Specs:
    Win 7 32bit, Q6600 G0, P5N32-E Sli Plus, 3GB DDR2, GTX460
    (1GB stick died on me)
    CPU-z link
  2. goldstar0011
    2 Sep 2007
    Is this any help?
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: bf3.exe
    Application Version: 1.0.0.0
    Application Timestamp: 4ece50fa
    Fault Module Name: bf3.exe
    Fault Module Version: 1.0.0.0
    Fault Module Timestamp: 4ece50fa
    Exception Code: c0000005
    Exception Offset: 00107e60
    OS Version: 6.1.7601.2.1.0.256.1
    Locale ID: 2057
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
  3. DIZZY DAZZLER 2010
    DIZZY DAZZLER 2010 Tech nut!
    23 Feb 2010
    I appear to suffer with bf3 crashing, however I think it was due to my gpu overclock. The problem I have is the game kicks me out to windows and the only way to get back is shut down the game and start again.
    Maybe a thought.
  4. goldstar0011
    2 Sep 2007
    No GPU overclock, trying Win7 64bit
  5. longweight
    7 May 2011
    I had random crashes until I updated my GPU drivers.
  6. deathbringer67
    deathbringer67 What's a Dremel?
    9 Nov 2009
    Hi
    Have you installed patches, think theres 2, they should install auto, i say because of your Application Version: 1.0.0.0 and Fault Module Version: 1.0.0.0, this looks to me like 1st version, i could be wrong.
    Try putting all your graphic settings to there lowest and see how that goes, theres also a lattancey option lower that to.
    Your system is much the same as mine. you do have a better gpu than me so u should be ok.
  7. The Janitor
    The Janitor What's a Dremel?
    15 Feb 2010
    Have you tried updating your audio and graphics drivers?
    You should be ok with the latest nvidia WHQL drivers (285.62) but if you have problems with triangular artifacts the more recent beta drivers (290.53) might be worth a try.
    Also, which GTX460 do you have? If its an ASUS one make sure you dont have GamerOSD installed as that can cause in-game stability issues and crashes at map change.
  8. wolf5ster
    wolf5ster Minimodder
    2 May 2011
    I've had crashes, since the beta just finally decided to track it down. Most of them have happened in caspian border. Possibility audio or LAN updated 2 to 3 days ago and seems to be ok so far.
    AMD 955@3.2ghz
    Gigabyte GMA880 USB 3
    Sapphire 6870 1GB
    8GB of G-SKILL 1333
  9. goldstar0011
    2 Sep 2007
    Seems all good since installing 64bit Windows, not been playing since accident dammit
  10. TraumaticHug
    TraumaticHug What's a Dremel?
    23 Apr 2011
    Do you have an ASUS graphics card and have yet to install the ASUS software?
    I ask as my brother had the same issue, but uninstalling the ASUS OSD and SmartDoctor stopped this (he may have had to reinstall vid drivers, too)
  11. zairs
    zairs What's a Dremel?
    30 Nov 2010
    ive been having problems too, also have an asus 470 will try uistaling OSD and smart doc what can i use instead of smart doc?
  12. zairs
    30 Nov 2010
    this seems to of worked for me, only got rid of osd, but so far so good
  13. longweight
    7 May 2011
    When you install an update do you click on clean install?
  14. The Janitor
    15 Feb 2010
    Yeah, the problem seems to be with GamerOSD, I was getting fairly frequent crashes at map changes until I uninstalled it.
  15. MSHunter
    MSHunter Minimodder
    24 Apr 2009
  16. legoman
    legoman breaker of things
    28 Feb 2010
    Ive had the same fault on two GPUs same error message as list, some were from a 460GTX and now from a 6950 using either the ASUS or AMD drivers. indicates to me its not GPU, but all my other drivers are up to date
