Big Ass Radiator Help
Discussion in 'Watercooling' started by Guest-23315, 26 Mar 2011.
  1. Guest-23315
    Guest-23315 Guest
    Pascal, I was wondering if you could give me a hand with some of the dimensions of some of the 9x120mm / 4x180mm radiators.
    According to the spec page, the dimensions are: 390x365x46mm
    Im curious, and I assume that the 390mm length is going to be long side that the barbs are going to exit from? Is that correct? And then how long would the shortest set of right angle barbs be?
    Im planning on shoving it in here
    :thumb:
  2. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    i believe so but i will check for you on monday :)
  3. Dackman
    Dackman What's a Dremel?
    23 Mar 2011
    Really tempted by one of these radiators, do you know what type of pump would be needed?
  4. Guest-23315
    Guest-23315 Guest
    You could probably get away with a D5.
  5. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Get a D5 Strong for it. It'll work pretty well.
    So, what are you planning to do with your big ass-radiator?
  6. Guest-23315
    Guest-23315 Guest
  7. Dackman
    23 Mar 2011
    I'm thinking of one of these to replace the top panel on a mm UFO
