Software Binocular effect
Discussion in 'Photography, Art & Design' started by Cptn-Inafinus, 5 Jul 2007.
  1. Cptn-Inafinus
    Cptn-Inafinus Minimodder
    3 Mar 2007
    Is there anyway i would be able to achieve the effect of looking down the wrong end of a set of binoculars in photoshop?
    Also for future reference. Is there anyway i can do this with lenses on D-SLR?
    Regards
    Inafinus
  2. OleJ
    OleJ Me!
    1 Jul 2007
    If I remember correctly looking down the wrong end just makes everything incredibly small?
    In case you want that, you could duplicate the background layer, shrink it, then add a thick black ring around it perhaps with a slight gradient and blur on outer and inner edges. Add two semi transparent white lines atop and bobs your uncle...?
    Otherwise I don't understand your question... Perhaps if you have a photo of the effect you could show to illustrate the effect?
  3. OleJ
    OleJ Me!
    1 Jul 2007
    Was this it?
  4. Cptn-Inafinus
    3 Mar 2007
    Yeah thats pretty much the effect i wanted, except without the are out side the binoculars.
    If you are wondering why i wanted it, its for a short film im making with my friends in the summer. Just a bit of a cheesy horror.
  5. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    just use a mask over the image. for added effect, add some lens distortion to each circle (there's a filter for that in PS but i forgot what it was called)
  6. OleJ
    OleJ Me!
    1 Jul 2007
    I believe what Fod refers to is lens correction.
    Just have fun with the stuff under "Filters->Distort"
    I made this for you:
    You might also be satisfied with "Pinch"
