Modding biometric scanners
Discussion in 'Modding' started by glaeken, 30 Apr 2005.
  1. glaeken
    glaeken Freeeeeeeze! I'm a cawp!
    1 Jan 2005
    Orlando, FL
    Does anyone know how to make one of these scanners act as a power button? Sorry if this has been mentioned...searched it but didnt find anyting.
    Thanks
  2. GuardianStorm
    GuardianStorm Minimodder
    26 Apr 2005
    Bournemouth
    would you like the scanner hard wired to the power switch, or somthing through software?
    what connections has the scanner got etc?
  3. glaeken
    1 Jan 2005
    Orlando, FL
    well i dont have one yet i just wanted to know if it was even possible. I was thinking of hard wiring it to the power switch.
  4. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    the blue nowhere
    I think that you would need a old pda hook a biometric scanner to that then
    rig it to turn the pc on when the scanner gets a match
  5. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    Nottingham
    Welcome to the forum glaeken.
    Not on its own. The scanner plate actually takes lots if images of your fingerprint and sends it to the PC, a bit like a webcam, via USB, parallel+PS2 or cordbus. The software then picks out key points of the print, and if correct, logs you into Windows. You would need another piece of hardware to recognise the signal input by it, check its correct and then short the power pins on your mobo. Somehow this would have to be tied in with the Windows boot sequence too.
    So in short, not really.
    You could have a touch-plate to turn the PC on (555 timer trigger and all that) and mount the fingerprint reader next to it to logon though. Could look good if you made them look identical and mounted them next to each other.
  6. glaeken
    1 Jan 2005
    Orlando, FL
    thanks for all the helpfull replies. Where could i get a touch plate, and are they expensive?
    thanks
  7. severedhead
    19 Dec 2002
    Nottingham
    All you need is a 555 timer circuit which you can build for peanuts and the plate can be anything metallic. I'll get more info for you when I get back home this afternoon.
  8. severedhead
    19 Dec 2002
    Nottingham
    With a bit of Google searching and my limited electronics knowledge I came across this whihc would probably be easier to make.
  9. Godboy_g
    Godboy_g What's a Dremel?
    13 Aug 2004
    Canada
    You couls also buy a biometric door lock, and wire that up to the power switch. As far as I know, you do not need to have them connected to a PC for them to work, and since the lock itself is mechanical, you may even be able to have it press a button to turn on the PC.
  10. th3Phallex
    th3Phallex What's a Dremel?
    7 Apr 2005
    port 80
    Whoah...
    Since some of us can't really read electrical diagrams, I'd really like to see a tutorial on how to make a touch-switch... do you think this would be hard for you/anyone to do?
    I wonder if you could wire one in your PC to control lights on/off...?? (This would work while the PC is on... I guess.)
    It would be nice to have a "hidden" button for my project...
  11. glaeken
    1 Jan 2005
    Orlando, FL
    yeah a guide would be really nice since I have very limited electrical experience. thanks for all the help.
  12. Seanz0rz
    Seanz0rz What's a Dremel?
    22 Apr 2005
    Redlands, CA, USA
    would be simple, just a relay in place of the motherboard in that diagram.
    btw, relay is a "electronic switch" when a current is passed through it, it closes the contacts and therefore completing the circuit on the other side.
  13. devenfore
    devenfore LANCandy
    8 Jul 2003
    USA
  14. th3Phallex
    7 Apr 2005
    port 80
    Thanks, but:
    I.) I know what a switch does.
    II.) My post says: "Since some of us can't really read electrical diagrams, I'd really like to see a tutorial on how to make a touch-switch... do you think this would be hard for you/anyone to do?".
    Therefore, I don't understand the diagram.
    I asked about this because I don't know the following:
    I.) What all the components are
    II.) how to connect them together (PCBoard??)
  15. severedhead
    19 Dec 2002
    Nottingham
    I'll check component availbility, have a fiddle and maybe post a quick guide if all works out OK. I remember making one of these for GCSE all those years ago, if I can find my little prototype I'll take a few pics. I'm working a lot at the minute though so don't expect anything straight away!
    In regards to the above diagram, the rectangles are resistors with the appropriate valie printed next to them, the big box is the MOSFET itself with its name next to it, 5V is the red wire in your PC and 0V is black. The finger contacts can be anything as long as they are quite close together.
    I use stripboard for my little projects, is cheap and easy. Google for it and its everywhere.
  16. th3Phallex
    7 Apr 2005
    port 80
    I think that would be really cool!
    Thanks!
    Cool, thanks for the info!
  17. Liquid Steele
    Liquid Steele What's a Dremel?
    11 Apr 2005
    Chicago IL.
    Just a suggestion and I know this is a little off of topic but if you want to do this for security then you would be better off waiting until june and purchasing PGP 6.0 it has a whole drive option where you can encrypt your whole C drive with 256 bit encryption a Cray computer could not even crack that encryption level. But it would not be nearly as cool as the Biometric switch it would however be wayyyy more secure I have the beta version if you would like to download it I can post a link here this is how it works when you boot your computer the first thing you get is a decrypt password once you enter that the computer will contue the boot process and voila you are up and running. No password no computer it is really that simple.
    Anyway I thought I would chime in with my 10 cents = ) :rock: :D
