Motherboards BIOS for P55M-UD4
Discussion in 'Hardware' started by zukomonitor, 12 Nov 2010.
  1. zukomonitor
    zukomonitor assumption is the mother of all....
    14 Sep 2010
    Hi guys, can I benefit from some of your knowledge please.........
    From what I can tell I have bios F3 and it says on Giga.com that i5 760 isnt supported till F9
    my pc is working now with the i5 in but I want to make sure everything is 'tip top' :D
    any advice??? giga.com also says to take small steps in the revisions like f3-5-7-f9 is this true or can I just flash F9 straight in?
    Cheers
  2. bulldogjeff
    2 Mar 2010
    It could be that each bios update just adds to whats already there rather than rewriting it. You haven't said what i5 if it's the 760 then you're sorted. The updates might just be to iron out a few bugs.
  3. zukomonitor
    14 Sep 2010
    sorry wasnt clear, yes ive got the i5 760 in now and running. but its not supported until bios F9
    what do you think I should do?
    cheers bulldog
  4. bulldogjeff
    2 Mar 2010
    One way to look at it is if it ain't broke, there's no need to fix it. Or you can run the gigabyte bios checker to see what one you've got installed and take it from there.
  5. zukomonitor
    14 Sep 2010
    true true, I think ill have a look at the 'bios checker' and do abit more research.
    cheers fella:thumb:
  6. zukomonitor
    14 Sep 2010
    decided to flash
    I decided to update the bios so downloaded F5, F7, F9 & F11 (im on F3)
    so using @bios utility I saved current F3 bios and then......
    accidentally flashed F9 first:wallbash: suppose thats why you should take your time doh!
    booted first time so restarted to make usual bios changes...... then it started playing up! so flashed back to F3 using Q flash and back to normal. phew
    so should I flash in increments then lol
    Bulldogjeff: that Bit Tech slogan is in my head! " if its broke fix it, if it isn't mod it!"
    lol
  7. zukomonitor
    14 Sep 2010
    BUMP :D
    Just looking for some guidance here guys n gals
  8. bulldogjeff
    2 Mar 2010
    Stick with what you've got fella unless theres a particular reason to change it, or do it in steps.
  9. zukomonitor
    14 Sep 2010
    I may regret it but I want the board up to date, bit of an OCD thing lol
    steps (3) to 5 -7 -9 -11 sound ok? I might stop at 9 as e few people have had problems with 11 and it seems 10 is just crap
    Thanks bulldog
    EDIT: ive made sure Ive got a backup of original bios in a safe place and theres the dual bios incase something goes t*ts up lol
