Displays Bit of a problem
Discussion in 'Hardware' started by Dopey, 27 Dec 2010.
  1. Dopey
    Dopey What's a Dremel?
    23 Oct 2010
    Hi all, again!! hope you all had a good Xmas and got what you wanted from Santa!!
    Anyway to my problem, when i boot my computer up the screen wont start, just says "no connection", i have to turn it off from the plug sometimes 2 or 3 times for say 10 secs or more, and then it come on as it should after booting the puter up i'm running win 7 and have an AMD chip
    AMD Phenom II X6 1055T 2.8GHz 9MB Cache Socket AM3 Retail Box Processor
    Asrock 890GX Extreme3 Socket AM3 DVI VGA HDMI Out 8 Channel Audio ATX Motherboard
    Gigabyte GTX 460 OC 1GB GDDR5 OC Edition Dual DVI HDMI PCI-E Graphics Card
  2. quirkalfeeg
    quirkalfeeg Its a trick...get an axe.
    6 Nov 2010
    Hi,
    "no connection" sounds like a bad connection to the boot drive. I had this this other day after gutting an old pc and had forgotten to plug the sata cable back into the boot drive..
    Standard i.t question - is the sata/power connection firmly in place on the drive/motherboard?
    Could be a bad sata cable/power cable, though not that likely I guess...?
    Has it been working fine up until recently? Have you been tinkering inside the case recently?
    Q.
  3. Remeniz
    Remeniz Muted!
    18 Dec 2010
    Mmmmmm. . .
    I thought "No Connection" displayed on the monitor meant that the monitor in question wasn't connected to the graphics card or isn't receiving a signal from the graphics card. Nothing to do with the hard drives.
    OP: Your running a motherboard with it's own graphics solution and you have a GTX 460. So go into the BIOS and ensure that you disable the on-board graphics.
    See if that helps.
  4. murraynt
    murraynt Modder
    6 Jun 2009
    Plug out the GFX and run it off the on-board VGA/DVI.
  5. Dopey
    23 Oct 2010
    Its a new build, and i plugged my old monitor in and the same thing happened, i will take the side off and check the plugs, and get back to you if its a fix or not... thanks guys
    Just to add the strange thing is, if i was to turn it off now, it would reboot as normal and the monitor would start up
  6. murraynt
    murraynt Modder
    6 Jun 2009
    Could be a dud 4600GTX well worth the simple check.
    I've have a few new parts come as duds especially RAM.
  7. Dopey
    23 Oct 2010
    Well it was working, its just the passed few weeks its been doing it
  8. Dopey
    23 Oct 2010
    went to the bios, and made it all as default, shut off the turbo boost, shut down, its been a few hours now before i started the puter up, and it cam on fist time as it should
