Cooling Bit of advice on fans
Discussion in 'Hardware' started by sjhujh, 29 Nov 2011.
  1. jtek
    jtek What's a Dremel?
    17 Feb 2009
    Does it have to be pwm? The yate 38mm would be awesome in front of a rad, all that pressure.
    pwm is backwards compatible with 3pin isn't it?
  2. Wing Zero
    Wing Zero Ita-sha owner
    28 Apr 2010
    Plymouth
    personal preference, i rig up every fan to the CPU PWM header and have automatic fan throttling. Since PWM is a switching 12V supply, fans tend to start up and run at lower RPMs than traditional 3pin fans do.
    as far as i'm aware, you can plug a 3pin fan onto a 4pin PWM socket, but you don't get PWM control. but plug a 4pin PWM plug onto a 3pin socket and you have to vary the supply voltage to get any speed control
    Oh and it'd have to be 25mm thick, i don't think i could get 38mm to fit
  3. Tangster
    23 May 2009
    York, UK
    Phobya Nano 2G's?
  4. sjhujh
    sjhujh Minimodder
    1 Feb 2008
    UK
