SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Well, you'll never learn about rendering if you can't bother to install a PDF reader to read how the program is used :/
  2. jezmck
    jezmck Minimodder
    25 Sep 2003
  3. ĿªЪяεġø™
    ĿªЪяεġø™ Rabbit Modder !
    19 Jun 2009
    No way I'm gonna be as good as you guys , but here's my shot :
    Thanks for watching :thumb:
  4. boogerlad
    boogerlad What's a Dremel?
    27 Jun 2009
    Is this material close enough to lian li brushed metal?
  5. Dark~3nergy
    14 Jan 2007
    boogerlad, it looks a bit too reflective imo, but otherwise yes.
    i'm working on something big :D
    applying textures takes so much time :/
  6. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Damn man I remember saying something about architectural designs a while back but that looks crazy! I pity the machine that has to render that thing lol
  7. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    After a bit of advice here from people who know 3ds Max and Mental Ray better than I do. Here's a quick test render (12 min) of the interior of part of my final year uni submissions. I wonder if anyone knows how to get a similar result but without the whiteout of the outside through the windows. It's set-up with a mental ray daylighting system for light. It's been rendered without Global Illumination.
    I've tried a number of different things, including reducing the exposure value and increasing both the sky and sun multipliers or increasing the global lighting level. Global illumination didn't seem to increase the brightness of the interior when I turned it on, and it also increased rendering time tinfold.
    Any hints are appreciated, otherwise I'll try and blend in some external views in photoshop.
    Anything else I can improve? DOF is something which I'll apply when I'm happy with the rest of the scene, and have imported some furniture into it. Cheers.
    Edit: an update on how it's coming along.
    Further edit. One more image, this time with Global Illumination turned on to 0.5 intestity.
  8. Raiden
    Raiden Portuguese reviewer
    26 Oct 2009
    You did this all by yourself?
    Every component?
    If yes it looks good , pratice makes perfection mate:thumb:
  9. Metric
    Metric has a bazooka
    1 Jun 2009
    Boogerlad: You're getting close, your bumpmap scale needs to be lower (looks too coarse). Also it looks like you're using displacement too which isn't necessary for details that small and will just cause longer render times.
    Some Maxwell materials in the works from me:
    Bitspower Matte Black w/ Gold Detailing
    Bitspower Chrome w/ Black Detailing
    Lian-Li Black Brushed Anodized Aluminum
  10. confusis
    confusis Kiwi-modder
    5 Jan 2006
    very very nice!
  11. Dark~3nergy
    14 Jan 2007
    awesome materials metric ! could you share the bump map you use for the brushed anodized aluminum ?
    soon done with my house :D
  12. Editor22
    3 Jan 2009
    I'll send you a message when I win the lottery dark :p
  13. Roboduck
    Roboduck 01110001 01110101 01100001 01100011
    1 Dec 2009
    Here are just a few quick renders of some concept cases. I didn't spend a whole lot of time on them just trying to get some ideas down. Let me know what you think!
    Ford Raptor SVT Case
  14. cronicash
    cronicash What's a Dremel?
    25 Aug 2009
    Nice revamped tj07's
  15. ĿªЪяεġø™
    19 Jun 2009
    No , not all :D just picking components from other models and get them all together :thumb:
    Another shot :
    What should I improve ?
    • Metal material ;
    • Some components missing ;
    • Dark plastic too dark ;
  16. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Fixed the image for you, vbulleting won't link pictures via https.
    Can't say I'm a fan of the 45 degree perspective tbh, a horizontal perspective would work better. Both the metal and the mainboard itself should be a bit more reflective.
    Edit: Doh, apparently it does. Oh well, no matter.
  17. Valdisnei
    Valdisnei Can i haz a dremelz!?
    22 Sep 2007
    I was testing the PhotoView360, a simple renderer wich came with SolidWorks. For easy and fast rendering, it does good results..
    I render an Advan RGII2 wheel SolidWorks drawn..
    The result:
    Cya! ;)
  18. stuartwood89
    20 Aug 2008
    If you're using Kerkythea, then try the MLT (Metropolis Light Transfer) setting in the render menu. It gives more realistic results. You may also want to download some metal material libraries from the KT site, you should be able to apply one of them without playing with any material settings and get some great results. Try applying globals instead of lights if you want an even coverage of light.
  19. Chaos_Engine
    Chaos_Engine What's a Dremel?
    16 May 2010
    awesome detail on motherboard, how long did it take you?
  20. Teyber
    Teyber ******
    18 Mar 2007
    hey metric, how did you get maxwell and how much did you pay for it?
    cheers
