BiT-Tech go Cancer Bashing......
Discussion in 'General' started by Koolvin, 17 Aug 2001.
  1. Koolvin
    Koolvin The Modfather
    12 Mar 2001
  2. howesey
    howesey What's a Dremel?
    17 Aug 2001
    For a little bit of CPU time I prefer to run Folding@Home ;)
    How does this program work. Does it run on spare CPU cyles or something?
  3. Forsaken
    Forsaken GameFaction.com
    27 Mar 2001
    Might as well do something useful with me spare cpu time :)
  4. Darkhorse
    Darkhorse What's a Dremel?
    2 Jul 2001
    Me too.
  5. Profezzor BoB
    Profezzor BoB I'm a cactus, please have sex with me.
    25 Jun 2001
    I run rc5 for Virtual Hideout :p
  6. Phil
    Phil What's a Dremel?
    19 Jul 2001
    i run rc5 in a small group of three people and we're not so far behind VH :D
  7. Profezzor BoB
    25 Jun 2001
    yes, but us stupid modders spend soo much money on windows and cathodes that we're stuck with no money, nicely modded cases, and no cpu power.
    check our stats on sept8 and sept9 though, look for the names profezzorbob@mailcity.com, ardelmius@ something whatever
    beltane@ something, and a bg.
    Massive rc5 dump :)
  8. Forsaken
    27 Mar 2001
    how long does an average UD agent unit take to complete, cos the fist few seemed to fly, and the last 2 have taken about 10 hours a go, on a 700 duron
  9. moose
    moose What's a Dremel?
    12 Mar 2001
    In my experience, it varies really.
    Some things take three hours on my 1.4GHz t-bird, others take 19 hours.
    Just depends on the complexity of the packet.
    Either way, you still get points equivalent to your system performance.
  10. Forsaken
    27 Mar 2001
    thanks, just upgraded to a 1.4GHz T-bird, see if that makes a diff :)
  11. RTT
    RTT #parp
    12 Mar 2001
    umm well im a seti fr34k..
    can i run both or would it slow each other down?
  12. Forsaken
    27 Mar 2001
    I used to run seti, but i think this is a bit more worthwhile.
  13. Phil
    19 Jul 2001
    yeah, they'd slow each other down - all these sorts of programs utilise CPU cycles that are 'spare' so if you're running one there won't be any spare any more
    be warned that these progs can hold you CPU at 100% usage for as long as you're running them, I fried a K6-3 450 this way a month ago while running distributed.net's RC5 program for 4 days in a row
  14. moose
    12 Mar 2001
    As long as you have adiquate cooling for your CPU, you'll be fine. :) All of my computers have the UD THINK agent running, thus 100% cpu usage, and they're on 24/7.
