Well for my two flushing tests, yes it required tipping around but i was able to get all the water drained.
Still need to work out what to do with the front panel design. I keep wondering about getting a nice piece of wood for the front. If I do that I’ll have to make it sit a little bit in front of the rad and then have air vents all the way down both sides. I also keep wondering if I should design something to print on my 3D printer. Thing is it would have to be printed in parts as my max print volume is 200x200x180. So not big enough to print it all in one piece. Any ideas?
Horizontal vanes that curve inward to your bit of wood? Hard to throw shape ideas at someone. As for draining: Do you have a wet vac?
Wet vac is a good idea, especially to get the last bit out... My new replacement ram heat shields arrived this week (first lot I bought through eBay were not addressable leds even though that’s what they were clearly described as... managed to get a refund through eBay), ordered them from Amazon. These look good and should help tie the ram into the colour scheme too plus add a bit more bling I’ll hopefully install them onto my ram on the weekend then I can actually fire up the pc for the first time and install the OS on it.
