Okay I can't really explain my situation but with what I'm doin im afraid that the double-sided tape for my window will show. i dont want that because the case is black and red. Is there black double sided tape out there?
if its clear dbl sided tape would it matter? never heard of black double sided tape but you could always use epoxy or super glue as an alternative
Any R/C guys out there? If so they can answer this question. Go to your local hobby shop that carries R/C cars. Ask for Servo Tape. It is very strong black double sided tape. If you do use it, put alot of weight or preasure on it for a few hours to get the best stick. Muratus
hmm clear wouldnt matter as long as its hard to see. is that black servo tape thick? i need it to be think because of the trimming.
The servo tape does have a foam middle. That is why you need to put alot of preasure or weight on it for a few hours. That will flatten it out. It is only about 1/16th thick when put on right.
yeah sure! me and StonieX are into R/C here in Autria i always used black double sided tape, you get it at every hobby shop as mentioned (team losi has a black one, but also team associated - you can find them on their website) - for rc anthusiasts: here's a link http://stud4.tuwien.ac.at/~e9725126/bodies/ i even was at european championships in tiverton in 2002 - you rock! so i see you're from california, this is rc-car heaven! there's another usefull link: http://www.teamlosi.com/links/index.htm scroll down to see some links where you can buy rc-stuff. they surely have black double sided servo tape.
