Black Light
Discussion in 'General' started by THEkorean, 27 Dec 2006.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    this question has been bugging me for a while, i was wondering if it is possible for any kind of device to emit a black light (as in truely black i.e. shine it on a white wall and a black spot will appear). I know that black is like all the colors of the visible light spectum being absorbed.. but that bring up the question, how do projectors create a black screen if it emits light...
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    magic, lol.
  3. iggy
    iggy Minimodder
    24 Jun 2002
    dear sweet baby jesus.
  4. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    Projectors don't create a "black" light. They just aren't projecting light at the areas of the screen that look dark. As projectors are used in dark rooms (to give the best picture) there are very few other light sources that can illuminate those dark areas of the screen.... hence they look black.
  5. dfhaii
    dfhaii internets
    24 Mar 2002
    I have a black hole for sale, careful not to put your fingers in it though.
  6. Mighty Yoshimi
    Mighty Yoshimi Motormouth
    4 Sep 2006
    is that not what we call the abscence of light? Does it not just create a silohette for black?
    And i think a black lens can allow the passage of light, not TRUE black anyway, as it would absorb all the light
    Some Nonsense about them
    black light actually turns out to be purple, or ultra violet, make your mind up! marketers :thumb:
  7. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    The original poster is talking about the colour black, while the poster above me is talking about black light (just another name for ultraviolet light).
    In response to your question, no, there is nothing out there because black light is no light, it is absense not just another colour. I suggest you read wikipedia if you want to learn more about light.
  8. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Hey now, this isn't THAT foolish of a question! I actually thought about this too, about a week ago!!
    Technically, there IS "black" light. Human eyes cannot see infrared light, therefore it appears to be "black" to us. Although, it will not occlude the reflection of visible light photons so it's not like there can ever be a shadow-casting flashlight.
    Whip out a camera and aim it at an IR remote control. Press some buttons and you'll see the LED as detected by the camera.
    There are IR photons. The human eye sees zero intensity. Zero intensity = black. Therefore IR = black light. =)
  9. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    So the camera would pick up the LEDs as glowing black? That would be so awesome :rock:
    but who knows with pics.. the black might just be white light inverted by some leet photoshop shaman
  10. Stuey
    20 Jan 2005
    Nonono, the camera picks up IR LED light as blue. The human eye cannot detect it so you cannot naturally see IR light. I was basically twisting things around b/c I'm a smart ass. But that's ok.
  11. JCBeastie
    JCBeastie What's a Dremel?
    10 Nov 2005
    I think you could acheive this with resonance. You'd need a a light with a waveform opposed to frequency of light you wish to negate, same principal behind noise cancelling but with light.
    Although lights annoying ability to be both particle and wave may render this impossible...
    If it would work you'd need a device to emit all the counter-frequencies as it would be very colour specific.
  12. ch424
    ch424 Design Warrior
    26 May 2004
    As JCBeastie says, you could use superposition to create a black spot - but creating a mini black hole would be easier.
  13. severedhead
    severedhead What's a Dremel?
    19 Dec 2002
    So instead of a light, a dark?
    I've thought about this a few times, would be cool, and massively confusing just seeing it!
  14. Moriquendi
    Moriquendi Bit Tech Biker
    3 Nov 2005
    I dont think you could use superposition because 'white' light is incoherent, certainly from a black body source like a tungsten filament in a projector.
    What we see as black in a projected image is just the absence of reflected light reaching our eyes from that portion of the image.
    Moriquendi
  15. Nexxo
    23 Oct 2001
    Actually, the question is not that dumb. Those of us who did not sleep through physics class undoubtedly remember the phenomenon of light interference. Shine a laser through two narrow slits at a screen and you get a nice zebra pattern of light and dark bands, as photons converge at wavelengths that are alternatingly in synchronous or inverse phase, thus reinforcing each other on cancelling each other out.
    So as JCbeastie suggests, in theory it would be possible to create a beam of darkness, if you can somehow manage to project photons on to a screen with a wavelength that is an exact match, but also in exact inverse phase with the photons that are already hitting that screen. In practice pretty much impossible, but in theory it can be done.
    Now on the: "How does a film projector project dark bits on a screen?". As Moriquendi says: it only looks dark in comparison with the lighter parts of the screen. Human vision is in fact crap at discerning absolute levels of brightness --it can only judge brightness of one spot relative to that of the surrounding area. So on a partially brightly lit screen, an unlit part will look dark in contrast.
  16. Guest-16
    Guest-16 Guest
    I cannot get this to work :/
  17. severedhead
    19 Dec 2002
    I cannot get this to make sense!
    So in a very basic manner of speaking, if the beam is the exact wavelength and opposite phase as the ambient light it can, in theory, cancel it out to provide darkness?
    Just like a headset with 2 mics to cancel out ambient sound?
  18. Krikkit
    21 Jan 2003
    Seriousleh? Lool. :p
  19. Mighty Yoshimi
    4 Sep 2006
    Constructive and destructive interfearance, can be used for many applications, measuring the thickness of hair, theres youngs double slit experiment. etcetc.
    Same happens with soundwaves, set two speakers up in mono, and sit them about 3 metres apart, get them to play a constant tone. So the Set up is like this.
    .............................Speakers
    /''''\ <- - 3Metres - -> /''''\
    l Stand about 2 metres away.
    -> Walk past them in the direction of the arrow (doesn't matter if you go from left to right or right to left, and the volume of the tone will vary as you get constructive and destructive interfearance.
  20. ch424
    26 May 2004
    Nexxo, that's what I said - and the people at CERN (or JET, I can't remember) recon they can make mini black holes... so there's more hope down that road :D
    I thought the point of the laser shining though two slits thing was the wave-particle duality: even if you only emit one photon at once, though the system, you still get the superposition - weird! Though I think QED explains it....
