AGP! I'm looking for a 'new' graphics card for my old pc. I rarely play games, this is more of a development machine. I do however run max / photoshop occasionally as well as doing a small amount of 3d development. Unfortunately I need an AGP card. It's really difficult to actually find reviews about them as it's such old tech, can anyone suggest anything with better price/performance than: http://www.ebuyer.com/product/185912 (powercolor HD4670 1GB for £70), I currently have a X700 pro but need more memory and dual DVI output. Any thoughts would be appreciated.
the 4650 and 4670 are very nice cards, under XP drivers are easy to install. however you hit a snag when it comes to the nforce 3 chipset. What motherboard you got?
Well, there is this, also at EBuyer. Should give you a bit more oomph than a 46xx card, unless you need UVD2. EDIT: Don't know if the 512MB is a deal breaker for you.
ABIT ic7 max 3, which I believe is the Intel chipset so all should be well... How much more oomph? Obviously, it's an earlier generation card, what would I lose out on other than memory?
personally i would get the 4670. However is it worth throwing £70 into that machine when ebay could turn up a bargin
I think it's a coin toss between the two. Not a bad call on ebay though - already seen some for a tenner less.
1GB 4650 for £56 You could pick up a VGA-DVI converter for a couple of quid, so all in all, under £60?
I don't think he needs a DVI->VGA converter (you can't go the other way). Usually I would have advised to take the same route I did, which was to switch the motherboard with one that has a PEG slot, but since the IC7-MAX3 is a socket 478 board I'm not even sure this would be possible.
Chances are with eBay he gets an oc'ed to death card. I'd be very wary of buying a graphics card off eBay. Also, as far as I recall, the only "7950GT" was the Gainward 7900GS. Gainward wasn't allowed to label it as it was. In any case it's the same GPU.
I've bought a X1650AGP from ebay for friend works well. Just read carefully and you'll be fine. And Use paypal.
