I use 200 for just about everything. And I get great pictures out of it My father is a camera nut, and he buys 200 for everything, even photo-shoots (he has done a few). I don't think you'll go wrong there One thing, though. Make sure your lighting is good. Plenty of natural light is just what the doctor ordered And don't underestimate the power of a little camera. Try some dark shots and see how they come out, you may be suprised (I surely have been).
Thanks again Yo-DUH_87! I have two questions.. I came across one of those neon wire light strings thingys...lol..the type that plug into your cars lighter socket. The lighter plugin part has been smashed to bits.. can I still use this??? If I can, what do I need to do to it to get it working?? I had another thought about the front of the case...use your imagination here ok? Remember my home made eject buttons? : I was wondering how it would look on the lower section, using the same method..it would eliminated the silver bar look..open it up more..it would match the eject buttons and all of the fans are also secured with them... Imagine...what do you think? Later guys DDK
What you mean take the black from the first pic down the both side of the fans? If so I tought this was finished
lol.. I just want to be satified with it.... Yes, I mean remove the two small 'bars' that are on each side of the lower fans. What holds that acrylic on is a small flexible alum rod, the 'bar' isnt really a bar, it's a "C" shaped alum piece that fits over the rod. I'm thinking of getting rid of that and using the push pin method....anyone that wants to try some PS skills again can give it a shot while I'm at work, that's if ya follow what I mean Is modding EVER done?? see ya tonight DDK edit : if you look back on page four theres a few shots of the front bezel, you can see the rod and C shape section...
I still keep comin back to look at the pics on this log. The name rules and so does the glowing logo What's your next project gonna be? Oh yea, and I think you should make a 3D rendering of the case so we can see all the little mods in 3D
HA, I can barely do a straight line in PAINT, let alone a 3d rendering!! Next project? Crap man, this ones taken so long and a chunkof money! There's still some thing to do before I call it totally done... Anyone know about my first question?? :I have two questions.. I came across one of those neon wire light strings thingys...lol..the type that plug into your cars lighter socket. The lighter plugin part has been smashed to bits.. can I still use this??? If I can, what do I need to do to it to get it working??: Thanks for any help regarding the neon string..stuff..lol... DDK
Most of the kits I have come across in my travels have had the inverter inside the jack that plugs into the lighter socket. In the case that it is beyond repair, you might just need a new inverter. Not all that hard to get ahold of This is of cource based on my experience and assumptions. If you had pics of the "smashed up bits" I may be able to extrapolate further...
Car voltage = 12v Puter voltage = 12v If there isn't an inverter or if the inverter isn't damaged you should be able to slap on a molex and hook it up - I ASSUME NO RESPONSIBILITY IF YOU HURT ANY PARTS, PEOPLE, CASES, OR SMALL FURRY ANIMALS NAMED FLUFFY.
Theres a little black box in the line thats ok...is that the inverter? Does the plug usually have a fuse or something in it?? DDK
hehe...ill try the molex... thanks DDK EDIT: Altron!! That was it! When I tried it before(long time ago) it didn't light up, must have had the wires wrong! HA! Bliss has UFO lighting now !! WEEEE!!!..WOOHOO! I'm going to be taking more pics tomorrow, crap you guys haven't seen, like the clear feet, the ghetto HD rack(WAY ghetto, but it's in the inside)..etc... Thanks Altron!
Final pics before hardware change I have just sent Yo-DUH_87 5 pics of the case. I took it outside to see if I could get better pics in outdoor lighting. I've posted some of these same types only indoor, but I took a shot of one of the clear feet I used. I will be changing the hardware over in an hour or so, wish me luck and if all goes well I'll be back on tonight! *crosses fingers* DDK
*drool* can't wait to see pics. I absolutely LOVE the black plexi with silver trim and the lit from behind lights, they are so cool that I will copy them MUHAHAHAHAHAHAHAHA
I love this case too, keep trying to think of something original to do to mine but end up back here at this thread.
ITS UP!! WOOHOOOOO!!! Just a test run.. need to shut down and put the tv tuner in and try the USB ports also....had to check to see I've I'd have any sparks, booms or fires... DDK
