Electronics blown fuse indicator circuit
Discussion in 'Modding' started by bigal, 14 Aug 2005.
  1. bigal
    bigal Fetch n Execute
    8 Oct 2004
    Hi, i am after a circuit that will light an LED if a fuse is blown, it needs to run at mains ( so +------|==3amp==|----[LOAD]------GND) with + and - being mains. the circuit here looked ideal: HERE except i cant help feeling it is not going to work.... if leds could be run of mains so easily, using one 100k resistor, it would be comon as hell. turbokeu has a circuit on his site here: http://www.turbokeu.com/myprojects/acled.htm for funning LEDs of mains and it is a lot more complex than the above! but not one for if a fuse was blown. Also the first site, on the second circuit for "Warning buzzer" the buzzer is shown connected directly over the 12v, so it would allways be on wouldent it? any ideas?
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    AFAICS the circuit's missing a high-voltage diode to block reverse voltage on the green led. :confused:
    The problem with resistor-only is it will produce a lot of heat (W = current2 x resistance), a series capacitor is better for dropping most of the extra volts as they produce imaginary heat, but they need 2-way flow as turbokeu's circuit.
    You could combine the two circuits, a single inverse diode will cover both leds.
  3. bigal
    8 Oct 2004
    lovely, so any 220nf cap (polysterine) rated at 240v will do then? D3, D4 and D5 woulkd 1n4007's do?
  4. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Should be rated 350V not 240V, and they want to be polypropylene rather than polystyrene.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Usually sold as Class Y2, X1 or X2, for continuous AC mains duty, and not expensive. 1N4004/5/6/7 are OK.
  6. bigal
    8 Oct 2004
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Rapid do about 4 in 220nF all suitable for mains use. They only specify 250V AC but that's OK for any UK mains application, equivalent to 350V peak.
    10-1342, 10-2680, 10-2778, 10-2494, all OK.
  8. bigal
    8 Oct 2004
    excellent, thanks alot! Will have to wait for enough stuff to order from them now... lol
    edit: found one 10-2778 in my stock... will try this out today!
  9. bigal
    8 Oct 2004
    does that 1k resistor have to be more than 1/4 watt?
  10. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Impedance of 220n+1k @50Hz is around 14.5k according to here so on 230V will give 16mA, resistor will produce I2R = 0.256W, so 0.5W is better. Or use 2 x 1/4W 470R in series, or 2 x 1/4W 2k in parallel.
    That 100k resistor in the first linked circuit, led current will be so low (2.3mA) it will probably survive the reverse voltage (for a few weeks). Still well dodgy. :nono:
  11. bigal
    8 Oct 2004
    all good and all working! Just need to get some more 220nf caps now!
    havent got enough on the books to order from rapid yet... looks like its going to have to wait...
  12. bigal
    8 Oct 2004
    it worked until i took the fuse out with the machine on (fuses doing there job) and there was a big flash and alot of buning smell... and the leds went black lol!
    decided to drop the idea...
  13. bwgames
    bwgames Minimodder
    6 Dec 2004
    Sounds like you tried to stick 230V through the LED... :( Short circuit?
  14. cpemma
    cpemma Ecky thump
    27 Nov 2001
    Is there a big transformer load?
  15. bigcatman
    bigcatman What's a Dremel?
    2 Dec 2011
    Hi All,
    I came across this thread whilst I was looking for the same idea as bigal and wondered if I can ask a question.
    I know the thread was posted quite a while back so I'm hoping someone out there can help
    Whilst looking for a solution to my problem, I've seen two diagrams on the net (one of which is mentioned in the thread, the other one uses a zener diode which is in line with a 1n4007 on the Live line)
    For the life of me I can't get both diagrams to work reliably (one only lights a single colour and the other does nothing).
    What I'm ideally looking for, is a mains fuse indicator which will illuminate a green LED for mains ok which then turns red if the fuse blows.
    I know my way around a schematic and good with electrics but I'm not so good at my electronics so I'd appreciate any help, or even a reliable schematic to solve this problem.
    Many thanks.
