News BrainChip boasts of industry-first neuromorphic SoC
Discussion in 'Article Discussion' started by bit-tech, 10 Sep 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Something i don't understand with these claims of chips that mimic how the brain works is how.
    If my understanding of the brain is correct don't neurons connect to each other via interneurons and those connections become stronger as we 'learn' things, if so how does fixed hardware go about strengthening particular pathways, how it works is set in stone after all, wouldn't it be the software (firmware) doing the changing?
  3. Gareth Halfacree
    4 Dec 2007
    Corky42 likes this.
  4. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    That's correct. Depending on how the chip is designed (anything from "just a big RAM bank that one or more processors scan over" to "a massive number of really really dumb networked cores") the 'connection' between 'neurons' is either entirely in software (determined by a set of addresses stored by that 'neuron' to indicate what others it is 'connected' to) or a set of physical connections to all (or a preset subset) of other neurons of which most remain unused. The latter is basically never implemented in hardware* as it means most of the silicon is wasted doing nothing, and can easily be replaced by a bus that does the same function but takes up less die area.
    *The exception being a handful of 'wetware' chips that dump a bunch of harvested neurons on top of a bunch of electrodes and let them form connections in response to stimuli. But at that point it;s less a chop and more head cheese.
  5. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    From the Wikipedia article:
    I wouldn't be surprised to see that emboldened by me bit 'edited' in future..
Tags: Add Tags
