Hardware Breaking Wind
Discussion in 'Article Discussion' started by Guest-16, 5 Jul 2008.
  1. Guest-16
    Guest-16 Guest
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    wow thats a late release, going to read it now.
    Edit: Nice bit of late night reading. looks live a very well put together little thing.
  3. Oclocker
    Oclocker What's a Dremel?
    21 Jun 2001
    oooh interesting.. but ya vandal any one who's been modding for a wee whilee (say 20 + years) can open anything and reassemble with warranty seals intact :)
    Seriously it looks far better in a technical way than an eeepc IMHO. external looks a dead heat ! Acer Aspire (blue) best looker by miles so hopefully you get one to strip (send it north & I'll strip it take pics - warranty seals intact gteed)F course due to trade secrets act nevr able to return it :)
  4. |V| 4 L k i 3 R
    |V| 4 L k i 3 R Minimodder
    5 Jul 2002
    Can we get a look at the opamps for audio? Would be a nice treat to upgrade the line out for the plane rides.
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    2GB RAM and replace HDD with SDD when price is right (up replace it with a 250GB). sounds like a perfect laptop compared to EEE's limited disk space
  6. DougEdey
    5 Jul 2005
    *titter*
  7. deeem119
    deeem119 What's a Dremel?
    5 Jul 2008
    Any chance of finding out which WLAN chipset is used?
  8. ChriX
    ChriX ^
    30 Aug 2001
    All of these seem to be getting further and further away from what made the EEE 701 good, it's price. It would be nice to see someone attempt to better the 701 at the same price rather than just upping the spec and price and getting closer to conventional laptops.
  9. Guest-16
    Guest-16 Guest
    The whole point about sub-notebooks is that they are not conventional notebooks.
    You can't have it both ways - it's either cheap or feature loaded. People complained the 701 wasn't enough - LCD size/hard drive etc, now they complain it's too expensive.
  10. ChriX
    ChriX ^
    30 Aug 2001
    My only complaint with my 701 was the dead pixel smack bang in the middle of the screen - if it wasn't for that it'd still be with me today. It was cheap so I don't expect features a-plenty, I'm just happy that it was cheap. :)
    Therefore I think it would be nice to see some competition at the same price point, rather than just moving up.
  11. Oclocker
    21 Jun 2001
    the Acer aspire 1 @199 quid upps spec a lot and cheaper - makes eee pc 701 look like the pile of tosh it is IMHO.
  12. B3CK
    B3CK Minimodder
    14 Jun 2004
    Any chance of getting info on what the maximum ram supported is? Say if I want to run linux with gobbles of ram?
  13. Guest-16
    Guest-16 Guest
    I'd guess the single DDR2 SO-DIMM size supported is 2GB if my memory on the 945 chipset serves correctly, so you'll max it out with 3. Why do you need so much?
    Nigel - we've asked for an Acer One :);)
  14. slugbug
    slugbug Going Broke Saving Money
    12 Nov 2007
    Nice thread title :thumb:
  15. Imothep
    Imothep What's a Dremel?
    6 Jul 2008
    Hi, I Have a Medion Akoya Mini (OEM Version of the MSI Wind). I just looked at the board, it is nearly the same! Even MS-No.111 Rev.1.0 is written at the back of the mainboard!
    It doesn´t have the onboard RAM and Bluetooth is missing.
    But as you can see http://scr3.golem.de/?d=0807/Medion-Test&a=60827&s=1 I hope the only thing that´s missing is the connector. So i want to know which Bluetooth Device is build in the MSI Wind, so I can buy the same. If I have enough time I will try to solder it in :)
  16. Dr. Strangelove
    Dr. Strangelove What's a Dremel?
    13 Mar 2005
    Did I miss it or is the picture of the Atom CPU missing? or does everyone know what they look like and find it boring? Oh and whats under that shiny piece of metal that sits between the south bridge and the memory slot? hehe I'm a curious type of guy....
    Anyway nice little article, I like it when you dismantle things like this!
  17. Oclocker
    21 Jun 2001
    you seen those tiny usb bluetooth dongles only protude around a cm max?
    ok robs a usb port but zero risk?
  18. Guest-16
    Guest-16 Guest
    The northbridge and CPU are under the metal heatspreader :) I thought everyone knew what they look like :blush:
    So to do: Pics of Atom and northbridge.
    Disassemble the wireless (might require soldering iron)
    and OpAMPs :eeek:
  19. Solinx
    Solinx What's a Dremel?
    1 Jun 2008
    The max total ram is 2GB. If you get the model with 1GB soldered, you can add only 1 more GB in the empty slot.
    Source: User experiences from forums.msiwind.net
    Source: http://forums.msiwind.net/mac-f32/wlan-thread-t813.html
    Good luck with your mods :)
  20. docsnyder007
    docsnyder007 What's a Dremel?
    16 Jul 2008
    Medion Akoya RAM
    Hi,
    so the Medion type has two RAM slots, and no RAM solderd in directly? Would be an advantage compared to the U100.
    Cheers,
    Daniel
Tags: Add Tags
