Displays Bright 5" Display?
Discussion in 'Hardware' started by Strudul, 22 Jan 2018.
  1. Strudul
    Strudul ~
    31 May 2010
    Need a display to be used as a digital dash for an open-wheel car (showing gear / rpm etc).
    Currently using one of these, but the brightness sucks, so looking for something better.
    Required:
    - Bright enough to see in direct sunlight (hood / sunshade can be attached)
    - 5"
    - HDMI input
    - Compatible with a Raspberry PI
    - Low power (5V / 2A ideally)
    Desired:
    - Touchscreen (ideally resistive)
    - Weatherproof
    - <£500
    Been looking at field monitors designed for use with cameras, but not sure if they'd be suitable or which to go for.
    Cheers
  2. Xlog
    Xlog Minimodder
    16 Dec 2006
    Ideally you'd want a transflective LCD, problem is the size. Usually anything under 6" is intended for embedded use and comes with parallel/spi/dsi interface. If you are willing, try searching for lcd and controller separately.
    If you can go a bit bigger, cartft.com has a number of models starting at 7".
    Field monitors will be about as suitable as anything else, they are ~500nits, so should be okayish with sun visor.
    Strudul likes this.
  3. RedFlames
    23 Apr 2009
    Doesn't the [full-size] pi come with a DSI slot?
    Strudul likes this.
  4. Strudul
    Strudul ~
    31 May 2010
    It does indeed and I am using the full-size RPi 3. Have used the official RPi touchscreen which connects through the DSI port in the past.
    Problem with that for this application is that the Pi is mounted about half a foot away and (although I may be wrong) a DSI ribbon cable looks a bit flimsy and unsuitable for outdoor use and the vibrations (and mechanical students) it'll be subjected to.
  5. Xlog
    Xlog Minimodder
    16 Dec 2006
    It does, but DSI can only be accessed through GPU, and anything GPU related is behind NDA. So as with camera, only RPi Foundation can implement new device support.
  6. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    A second-hand braodcast monitor plus a HDMI-SDI converter would probable the the cheapest option that doesn't involve tearing apart a display panel and creating your own backlight, or sourcing random bits off of Alibaba/Taobao (high-brightness panel + panel controller and hope the two use compatible LVDS timings).
    Or you could take a punt on a cheap AliExpress panel that dubiously claims "Over1000cd/m" and "Brightness: 800cd/㎡" within a paragraph of each other.
