Cases Broken button on Silverstone Raven 2
Discussion in 'Hardware' started by JY_OC_HX, 22 Oct 2012.
  1. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    More of a quick canvass of opinion more than anything. About 2 and a bit years ago i bought the Silverstone raven 2. (Pre air penetrators). This weekend the power button has ceased to function. It can't have been pressed more than 1000 times. Should i even try and bother getting silverstone to sort it or am i expecting far too much for a button to function more than 600 (by my reckoning) times over a 2 year period.
  2. megadriveguy
    megadriveguy Minimodder
    19 May 2010
    They might send you a new power button if you email, the wires have probably just come loose you can normally solder them back on easily
    Or just plug the reset switch to the motherboards power header
    JY_OC_HX likes this.
  3. ferret141
    ferret141 Minimodder
    18 Oct 2010
    My personal expectation would be at least 5 years. Hopefully someone more knowledgeble in consumer laws writes something.
    EDIT: Megadriveguy is on the right track.
  4. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    Thanks for the replies. I was just trying to gauge how helpful silverstone might be before i get in contact with them.
  5. Williz
    Williz Minimodder
    9 Mar 2012
    They can take awhile to reply but I did manage to get one of my AP fans replaced by them for free :)
  6. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    Good to hear. I've messaged them now. Thanks for the replies.
  7. ferret141
    18 Oct 2010
    How likely do you think they'll replace a sidepanel?
  8. Williz
    Williz Minimodder
    9 Mar 2012
    Not very as they are kinda heavy to post! Might as well try your luck though.
  9. ferret141
    18 Oct 2010
    Window side took a 20cm drop and chipped the paint.
  10. megadriveguy
    19 May 2010
    They wont replace that, they may sell you a panel if they have spares but it wont be cheap
    I wouldn't bother
  11. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Eh, just get some filler on that and a bit of paint.
  12. ferret141
    18 Oct 2010
    I'm peeved that it's on the window side.
  13. JY_OC_HX
    JY_OC_HX Minimodder
    2 Feb 2011
    Give them a try i got a reply within a couple of hours. All they wanted was my invoiuce, serial number and an address. They might charge you a bit with it being a bit heavier but you've nowt to lose.
