Playstation 3 Broken PS3 Pad
Discussion in 'Gaming' started by Quattro D, 5 Jun 2010.
  1. Quattro D
    Quattro D What's a Dremel?
    4 Jun 2010
    I bought my ps3 pad in nov 09, but now the Rubber bit of the Left Stick now twists and twirls about and no I dont have gamer rage or button bash.
    I rang the retailer and they said ring sony
    I rang Sony and they say is was accidental damage. :miffed:, rubbish i did nothing, and so they wont replace it, so what should I do
  2. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    for the hassel you are going to get chasing sony youd be better off just buying another, should be ale to get one for around 15 quid if you show around.
  3. Edge102030
    Edge102030 Son, i am disappoint.
    21 Aug 2009
    EDIT: oh right i understand what you're saying, the actual plastic stick twiddles around. Maybe you can reseat it? If sony won't fix/replace it tear it open and see if it is seated properly.
  4. Quattro D
    4 Jun 2010
    So calling them back and shouting as loud as I can is out of the question???
    Well I would buy another pad but I cant really afford it as I'm using my disposable income on my new build :(
    wait... £15 quid you say from where??? Most of them are £34-35
  5. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Sjould be a pretty east fix. take it apart and line the two "spikes" on the analouge sticks interior with the holes in the plastic analogue stick cover.
  6. Quattro D
    4 Jun 2010
    are you talking brand new original sony dualshock 3 pads for £15??
  7. Quattro D
    4 Jun 2010
    Right so if I was to fix it should super glue do the job???
  8. Edge102030
    21 Aug 2009
    Prob best trying epoxy if you're gluing metal to plastic. But i reckon it has just come unseated i don't think anything is broken.
    Edit: I'm confused here, is it the actual entire left stick that is spinning or the rubber grip on top? Can we have some clarity or a video.
  9. Quattro D
    4 Jun 2010
    Sorry my fault
    basically the analogue stick is fine, and is in the correct position
    But
    The Rubber bit that covers the tops of the stick now twirly and moves kind of like a dial.
  10. Edge102030
    21 Aug 2009
    Oh right, pull it off and stick it back down with glue. Simples :).
  11. Quattro D
    4 Jun 2010
  12. Quattro D
    4 Jun 2010
    thanks edge I will probabily do this when I can find the stupid glue :D
  13. lmth
    lmth What's a Dremel?
    29 Jun 2010
    It is same to me.... but I bought the new one from the shop and it is £32.
