Memory Broken RAM module - will it still function?
Discussion in 'Hardware' started by abezors, 17 May 2010.
  1. abezors
    abezors Lurking since '08
    21 Apr 2010
    So I was removing an Arctic Cooling RC heatspreader from my DDR2 Crucial Ballistix - and the thermal tape clean ripped one of the 128mb memory chips off the PCB! /facepalms
    So a question for anyone who has tried:
    - Will a RAM stick still work if it is missing one chip?
    I'm expecting either answer:
    "yes it will be normal but reduced by 128mb of capacity"
    "No way fool!"
    Yes I could try it myself, but I don't want to do even more damage (eg fry the motherboard etc).
    Bare this in mind if you buy the (normal, not Pro version) Arctic Cooling RCs, the stock thermal tape is awful - barely strong enough to hold the heat spreader securely onto the RAM 24/7, but too strong that it breaks memory chips off the RAM when you want to remove it.... :sigh:
  2. capnPedro
    11 Apr 2007
    I would be very surprised if it does work.
  3. mrbungle
    20 Sep 2004
  4. abezors
    21 Apr 2010
    Righto, thanks for the replies. I was fearing the worst anyway
  5. bulldogjeff
    2 Mar 2010
    thats 3 no's then
  6. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    make that 4 no's, but i could be wrong
  7. lysaer
    lysaer Suck my unit! Kirk lazarus (2008)
    15 May 2010
    "No way fool!" :D
  8. Neox010
    Neox010 EvE Addict
    24 Feb 2010
    Not unless you have the A-team next door.
  9. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    I think you should try it anyway.
    Who knows, maybe you'll discover a whole new market oportunity for 'damaged' ram :p
    But I'm still going to say it wont work
  10. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    There wont be the correct amount of memory addresses, so I think it will be rejected. I'd love to be proved wrong though. :)
  11. Jim
    Jim Ineptimodder
    2 Sep 2007
    Obviously not, but if you glue the module back on it'll be fine.
  12. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    If the stick is really, really borked by the loss of one chip, you may damage your motherboard trying to boot the PC with the damaged stick in.
