HTPC BSOD CLOCK_WATCHDOG_TIMEOUT
Discussion in 'Tech Support' started by Uggers, 12 Feb 2013.
  1. Uggers
    Uggers What's a Dremel?
    17 May 2009
    Hey All,
    My new HTPC is currently BSODing when attempt to play any games.
    I'm not going for anything really hard graphics wise, but it seems to trigger when I have a 3D app going.
    The specs are;
    • Microsoft Windows 8 Pro 64-bit
    • AMD A8-5600K
    • Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory @ 798MHz (11-11-11-30)
    • ASRock FM2A75M-ITX (CPUSocket)
    • AMD Radeon HD 7560D (On CPU)
    • 60GB M4-CT064 M4SSD2 SATA Disk Device (SSD)
    This was the BSOD report;
    Any advice at all, I haven't attempted to overclock it and the temperatures are all fairly low when in use.
  2. longweight
    7 May 2011
    That isn't an OC issue it is to do with the internal timing loop. Maybe try popping the battery out of the motherboard and leaving it for a few minutes.
  3. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    Disable AMD Boost or Auto OC.
    This will stop it. Cruddy AMD's :/
  4. bulldogjeff
    2 Mar 2010
    The \ntoskrnl.exe could also indicate a driver fault, probably GPU.
