Windows bsod Help please
Discussion in 'Tech Support' started by Bloodburgers, 2 Jun 2010.
  1. Bloodburgers
    Bloodburgers Minimodder
    30 Apr 2009
    My father's pc is giving him gyp.
    It loads up so far gets into windows and is halfway through starting up and then Boom BSOD.
    The error message displayed says
    Filter.sys
    page_fault_in_nonpaged_area
    then gives me a code (0x92567ec3, 0x00000000, 0xbae5a4fc, 0x00000000)
    if anyone has an inkling as to what may be causing this or more importantly a way to fix it i would be most grateful.
    As always thanks in advance.
  2. bulldogjeff
    2 Mar 2010
    I think this is a corrupted file code.What you need to run the windows disc and tell it to repair on reinstall the necessary drivers. If you can get into windows in safe mode run something like maleware bytes to see if there's any hidden nasties.
